Spline curves February 05, 2010 07:46AM |
BeagleFury
I based my brainstorming on the idea that from the host perspective, I probably want to have 5-10 pending requests always waiting to be sent to the firmware. Discarding and retransmitting all of those costs very little on the host (As the buffer size in firmware may be limited... at best case, it might have a 2 or 3 out of order reconstruction it could possibly do, but that makes it more complicated...)
I've also made statements assuming people already know what I'm working on. smiling smiley Sorry about that. The system I'm working on implements following spline curves on the firmware. My firmware will be GCode illiterate because it is too computational expensive to turn lines into a two linkage polar arm form. I've got the cubic spline math working at ~15 microseconds per spline step on an arduino mega; To drive a 5D robot, I'll need 5 splines per path descriptor (less than .1 milliseconds for spline stepping.) I believe doing it this way greatly simplifies how the firmware operates, reducing all motion to a 5 dimentional spline curve (2 polar arms, 1 linear arm, the extrusion 'position', and the temperature); my accuracy for transforming linear to polar depends completely on my bandwidth, and the fixed point accuracy for which I've coded the firmware; it is currently a 16 bit integer + 32 bit binary fraction (over 2^32), with ranges limiting some of the components (160 bits total for spine step state -- each step requires 16 single byte ADD or ADC operations on the data structure). Sorry if that is a bit complex, but I have difficultly describing it in words. The code will probably be shorter than the paragraph I wrote. smiling smiley
Re: Spline curves February 05, 2010 08:58AM |
Re: Spline curves February 05, 2010 04:26PM |
The greater the number of curve segments, the smoother the
curve, and the longer it takes to generate and draw. The number
below was pulled from a hat. It is best for printing.
#define SEGMENTS 16
static Fixed weight1[SEGMENTS +1];
static Fixed weight2[SEGMENTS +1];
#define w1(s) weight1[ s]
#define w2(s) weight2[ s]
#define w3(s) weight2[SEGMENTS - s]
#define w4(s) weight1[SEGMENTS - s]
* SetupBezier - one time setup code.
* Compute the weights for the Bezier function.
* For Speed and space - Precompute this table.
void SetupBezier(void) {
Fixed t, zero, one;
int s;
zero = FixRatio(0,1);
one = FixRatio(1,1);
weight1[0] = one;
weight2[0] = zero;
for (s = 1; s < SEGMENTS; ++s) {
t = FixRatio(s, SEGMENTS);
weight1[ s] = FixMul(one -t, FixMul(one - t, one - t));
weight2[ s] = 3 * FixMul(t, FixMul(t - one, t - one ));
weight1[SEGMENTS] = zero;
weight2[SEGMENTS] = zero;
* compute segments for the Bezier curve,
* since the curve touches the endpoints, the endpoints are not
* computed.
static void computeSegments(p1, p2, p3, p4, segment)
Point p1, p2, p3, p4;
Point segment[];
int s;
segment[0] = p1;
segment[ s].v = FixRound(w1(s) * p1.v + w2(s) * p2.v +
w3(s) * p3.v + w4(s) * p4.v);
segment[ s].h = FixRound(w1(s) * p1.h + w2(s) * p2.h +
w3(s) * p3.h + w4(s) * p4.h);
segment[SEGMENTS] = p4;
* BezierCurve -
* Draw a curve with the given endpoints(p1,p4), and the
* given control points (p2,p3)
* This version does not handle the pen or the mode.
void BezierCurve(p1, p2, p3, p4)
int s;
Point segment[SEGMENTS + 1];
computeSegments(p1, p2, p3, p4, segment);
PushMove(segment[0].h, segment[0].v);
for (s = 1; s <= SEGMENTS; ++s) {
if (segment[ s].h != segment[s - 1].h ||
segment [ s].v != segment[s - 1].v ) {
PushLine(segment[ s].h, segment[ s].v);
