Getting more speed out of Arduino Mega May 30, 2015 01:56PM |
clamp_to_software_endstops(destination); previous_millis_cmd = millis(); #ifdef DELTA float difference[NUM_AXIS]; for (int8_t i=0; i < NUM_AXIS; i++) { difference = destination - current_position; } float cartesian_mm = sqrt(sq(difference[X_AXIS]) + sq(difference[Y_AXIS]) + sq(difference[Z_AXIS])); if (cartesian_mm < 0.000001) { cartesian_mm = abs(difference[E_AXIS]); } if (cartesian_mm < 0.000001) { return; } float seconds = 6000 * cartesian_mm / feedrate / feedmultiply; int steps = max(1, int(delta_segments_per_second * seconds)); // SERIAL_ECHOPGM("mm="); SERIAL_ECHO(cartesian_mm); // SERIAL_ECHOPGM(" seconds="); SERIAL_ECHO(seconds); // SERIAL_ECHOPGM(" steps="); SERIAL_ECHOLN(steps); for (int s = 1; s <= steps; s++) { float fraction = float(s) / float(steps); for(int8_t i=0; i < NUM_AXIS; i++) { destination = current_position + difference * fraction; } calculate_delta(destination); plan_buffer_line(delta[X_AXIS], delta[Y_AXIS], delta[Z_AXIS], destination[E_AXIS], feedrate*feedmultiply/60/100.0, active_extruder); } #endif // DELTALet's break it down.
clamp_to_software_endstops(destination);So this calls a function to check if we are outside of range. Ok, but we are making a function call for a couple of if's. This means that for a couple of if's, we are storing some stuff on stack, jumping to subroutine, doing the if's, jumping back, restoring stuff from stack...all of this takes time, which we don't have. So instead just replace function call with what's inside of the function:
if (min_software_endstops) { if (destination[X_AXIS] < min_pos[X_AXIS]) destination[X_AXIS] = min_pos[X_AXIS]; if (destination[Y_AXIS] < min_pos[Y_AXIS]) destination[Y_AXIS] = min_pos[Y_AXIS]; if (destination[Z_AXIS] < min_pos[Z_AXIS]) destination[Z_AXIS] = min_pos[Z_AXIS]; } if (max_software_endstops) { if (destination[X_AXIS] > max_pos[X_AXIS]) destination[X_AXIS] = max_pos[X_AXIS]; if (destination[Y_AXIS] > max_pos[Y_AXIS]) destination[Y_AXIS] = max_pos[Y_AXIS]; if (destination[Z_AXIS] > max_pos[Z_AXIS]) destination[Z_AXIS] = max_pos[Z_AXIS]; }This takes up more flash, but flash we have in abundance.
for (int8_t i=0; i < NUM_AXIS; i++) { difference = destination - current_position; }Ok, this is nice to have so that we can automatically support any number of axis...but for me, this is unnecessary looping. Shure, not much time to save, but let's do it anyway.
difference[0] = destination[0] - current_position[0]; difference[1] = destination[1] - current_position[1]; difference[2] = destination[2] - current_position[2]; difference[3] = destination[3] - current_position[3];Again couple of ticks saved.
if (cartesian_mm < 0.000001) { cartesian_mm = abs(difference[E_AXIS]); } if (cartesian_mm < 0.000001) { return; }Doing same compare twice? What for?
if (cartesian_mm < 0.000001) { cartesian_mm = abs(difference[E_AXIS]); return; }
float seconds = 6000 * cartesian_mm / feedrate / feedmultiply; int steps = max(1, int(delta_segments_per_second * seconds));I had a particular problem with this piece of code. So we are using feedrate to calculate number of delta segments? This means that for different feed rates, we get different accuracy. For example, 1 mm at 20 mm/sec has 10 segments, at twice the speed 5 segments and so on. So instead let's use segments per mm so we get some consistency.
float fTemp = cartesian_mm * 5; int steps = (int)fTemp;Also note that we removed a division, which takes a bunch more time to complete than multiplication. Also by multiplying distance before converting to int, we get correct steps for fractions of millimeters.
for (int s = 1; s <= steps; s++) { float fraction = float(s) / float(steps); for(int8_t i=0; i < NUM_AXIS; i++) { destination = current_position + difference * fraction; }For each step one division, 4 additions, 4 multiplications. Let's see what we can do.
float addDistance[NUM_AXIS]; float fractions[NUM_AXIS];Then we make shure that there is at least one step, we precalculate fractions - distance moved for each axis in one segment and we zero distance added.
if(0 == steps) { steps = 1; fractions[0] = difference[0]; fractions[1] = difference[1]; fractions[2] = difference[2]; fractions[3] = difference[3]; } else { fTemp = 1 / float(steps); fractions[0] = difference[0] * fTemp; fractions[1] = difference[1] * fTemp; fractions[2] = difference[2] * fTemp; fractions[3] = difference[3] * fTemp; } // For number of steps, for each step add one fraction // First, set initial destination to current position addDistance[0] = 0.0; addDistance[1] = 0.0; addDistance[2] = 0.0; addDistance[3] = 0.0;
// Add step fraction addDistance[0] += fractions[0]; addDistance[1] += fractions[1]; addDistance[2] += fractions[2]; addDistance[3] += fractions[3]; // Add to destination destination[0] = current_position[0] + addDistance[0]; destination[1] = current_position[1] + addDistance[1]; destination[2] = current_position[2] + addDistance[2]; destination[3] = current_position[3] + addDistance[3];
calculate_delta(destination);Again replace function call with code:
// X axis delta[X_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower1_x-destination[X_AXIS]; delta[X_AXIS] -= (fTemp * fTemp); fTemp = delta_tower1_y-destination[Y_AXIS]; delta[X_AXIS] -= (fTemp * fTemp); delta[X_AXIS] = sqrt(delta[X_AXIS]); delta[X_AXIS] += destination[Z_AXIS]; // Y axis delta[Y_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower2_x-destination[X_AXIS]; delta[Y_AXIS] -= (fTemp * fTemp); fTemp = delta_tower2_y-destination[Y_AXIS]; delta[Y_AXIS] -= (fTemp * fTemp); delta[Y_AXIS] = sqrt(delta[Y_AXIS]); delta[Y_AXIS] += destination[Z_AXIS]; // Z axis delta[Z_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower3_x-destination[X_AXIS]; delta[Z_AXIS] -= (fTemp * fTemp); fTemp = delta_tower3_y-destination[Y_AXIS]; delta[Z_AXIS] -= (fTemp * fTemp); delta[Z_AXIS] = sqrt(delta[Z_AXIS]); delta[Z_AXIS] += destination[Z_AXIS];
// Adjust delta float grid_x = destination[X_AXIS] * AUTOLEVEL_GRID_MULTI;// / AUTOLEVEL_GRID; if(2.999 < grid_x) grid_x = 2.999; else if(-2.999 > grid_x) grid_x = -2.999; float grid_y = destination[Y_AXIS] * AUTOLEVEL_GRID_MULTI;// / AUTOLEVEL_GRID; if(2.999 < grid_y) grid_y = 2.999; else if(-2.999 > grid_y) grid_y = -2.999; int floor_x = floor(grid_x); int floor_y = floor(grid_y); float ratio_x = grid_x - floor_x; float ratio_y = grid_y - floor_y; float z1 = bed_level[floor_x+3][floor_y+3]; float z2 = bed_level[floor_x+3][floor_y+4]; float z3 = bed_level[floor_x+4][floor_y+3]; float z4 = bed_level[floor_x+4][floor_y+4]; float left = (1-ratio_y)*z1 + ratio_y*z2; float right = (1-ratio_y)*z3 + ratio_y*z4; float offset = (1-ratio_x)*left + ratio_x*right; delta[X_AXIS] += offset; delta[Y_AXIS] += offset; delta[Z_AXIS] += offset;And last, the code:
plan_buffer_line(delta[X_AXIS], delta[Y_AXIS], delta[Z_AXIS], destination[E_AXIS], feedrate*feedmultiply/60/100.0, active_extruder);feedrate*feedmultiply/60/100.0 is calculated every time we go through the loop, even though it stays the same. So we calculate it once before the loop and use that value for each iteration.
// clamp_to_software_endstops(destination); if (min_software_endstops) { if (destination[X_AXIS] < min_pos[X_AXIS]) destination[X_AXIS] = min_pos[X_AXIS]; if (destination[Y_AXIS] < min_pos[Y_AXIS]) destination[Y_AXIS] = min_pos[Y_AXIS]; if (destination[Z_AXIS] < min_pos[Z_AXIS]) destination[Z_AXIS] = min_pos[Z_AXIS]; } if (max_software_endstops) { if (destination[X_AXIS] > max_pos[X_AXIS]) destination[X_AXIS] = max_pos[X_AXIS]; if (destination[Y_AXIS] > max_pos[Y_AXIS]) destination[Y_AXIS] = max_pos[Y_AXIS]; if (destination[Z_AXIS] > max_pos[Z_AXIS]) destination[Z_AXIS] = max_pos[Z_AXIS]; } previous_millis_cmd = millis(); #ifdef DELTA float difference[NUM_AXIS]; float addDistance[NUM_AXIS]; float fractions[NUM_AXIS]; difference[0] = destination[0] - current_position[0]; difference[1] = destination[1] - current_position[1]; difference[2] = destination[2] - current_position[2]; difference[3] = destination[3] - current_position[3]; float cartesian_mm = difference[X_AXIS] * difference[X_AXIS]; cartesian_mm += (difference[Y_AXIS] * difference[Y_AXIS]); cartesian_mm += (difference[Z_AXIS] * difference[Z_AXIS]); cartesian_mm = sqrt(cartesian_mm); if (cartesian_mm < 0.000001) { cartesian_mm = abs(difference[E_AXIS]); return; } //float frfm = feedrate * feedmultiply; /* // For 1 mm, steps are ((6000 * 1) / (1200 * 100)) * 200 float seconds = 6000 * cartesian_mm / frfm;// feedrate / feedmultiply; // int steps = max(1, int(DELTA_SEGMENTS_PER_SECOND * seconds)); int steps = int(DELTA_SEGMENTS_PER_SECOND * seconds); if(1 > steps) steps = 1; */ // Using steps per mm makes much more sense //int mms = (int)cartesian_mm; float fTemp = cartesian_mm * 5; int steps = (int)fTemp; // At least one step // Calculate step and fraction if(0 == steps) { steps = 1; fractions[0] = difference[0]; fractions[1] = difference[1]; fractions[2] = difference[2]; fractions[3] = difference[3]; } else { fTemp = 1 / float(steps); fractions[0] = difference[0] * fTemp; fractions[1] = difference[1] * fTemp; fractions[2] = difference[2] * fTemp; fractions[3] = difference[3] * fTemp; } // For number of steps, for each step add one fraction // First, set initial destination to current position addDistance[0] = 0.0; addDistance[1] = 0.0; addDistance[2] = 0.0; addDistance[3] = 0.0; // Calculate feedrate*feedmultiply/60/100.0 // We use this in each for iteration float frfm = feedrate*feedmultiply/60/100.0; // Then add fraction for each segment step for (int s = 1; s <= steps; s++) { // Add step fraction addDistance[0] += fractions[0]; addDistance[1] += fractions[1]; addDistance[2] += fractions[2]; addDistance[3] += fractions[3]; // Add to destination destination[0] = current_position[0] + addDistance[0]; destination[1] = current_position[1] + addDistance[1]; destination[2] = current_position[2] + addDistance[2]; destination[3] = current_position[3] + addDistance[3]; // Calculate delta // X axis delta[X_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower1_x-destination[X_AXIS]; delta[X_AXIS] -= (fTemp * fTemp); fTemp = delta_tower1_y-destination[Y_AXIS]; delta[X_AXIS] -= (fTemp * fTemp); delta[X_AXIS] = sqrt(delta[X_AXIS]); delta[X_AXIS] += destination[Z_AXIS]; // Y axis delta[Y_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower2_x-destination[X_AXIS]; delta[Y_AXIS] -= (fTemp * fTemp); fTemp = delta_tower2_y-destination[Y_AXIS]; delta[Y_AXIS] -= (fTemp * fTemp); delta[Y_AXIS] = sqrt(delta[Y_AXIS]); delta[Y_AXIS] += destination[Z_AXIS]; // Z axis delta[Z_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower3_x-destination[X_AXIS]; delta[Z_AXIS] -= (fTemp * fTemp); fTemp = delta_tower3_y-destination[Y_AXIS]; delta[Z_AXIS] -= (fTemp * fTemp); delta[Z_AXIS] = sqrt(delta[Z_AXIS]); delta[Z_AXIS] += destination[Z_AXIS]; // Adjust delta float grid_x = destination[X_AXIS] * AUTOLEVEL_GRID_MULTI;// / AUTOLEVEL_GRID; if(2.999 < grid_x) grid_x = 2.999; else if(-2.999 > grid_x) grid_x = -2.999; float grid_y = destination[Y_AXIS] * AUTOLEVEL_GRID_MULTI;// / AUTOLEVEL_GRID; if(2.999 < grid_y) grid_y = 2.999; else if(-2.999 > grid_y) grid_y = -2.999; int floor_x = floor(grid_x); int floor_y = floor(grid_y); float ratio_x = grid_x - floor_x; float ratio_y = grid_y - floor_y; float z1 = bed_level[floor_x+3][floor_y+3]; float z2 = bed_level[floor_x+3][floor_y+4]; float z3 = bed_level[floor_x+4][floor_y+3]; float z4 = bed_level[floor_x+4][floor_y+4]; float left = (1-ratio_y)*z1 + ratio_y*z2; float right = (1-ratio_y)*z3 + ratio_y*z4; float offset = (1-ratio_x)*left + ratio_x*right; delta[X_AXIS] += offset; delta[Y_AXIS] += offset; delta[Z_AXIS] += offset; plan_buffer_line(delta[X_AXIS], delta[Y_AXIS], delta[Z_AXIS], destination[E_AXIS], frfm, active_extruder); } #else
Re: Getting more speed out of Arduino Mega May 30, 2015 11:39PM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Getting more speed out of Arduino Mega May 31, 2015 01:56AM |
if (cartesian_mm < 0.000001) { cartesian_mm = abs(difference[E_AXIS]); } if (cartesian_mm < 0.000001) { return; }Had a reason.
if (cartesian_mm < 0.000001) { cartesian_mm = abs(difference[E_AXIS]); if(cartesian_mm < 0.000001) { return; } }If we just want to extrude some filament, my first solution won't do anything - it will just return without queueing any moves. The check before return makes shure that this does not happen.
Re: Getting more speed out of Arduino Mega May 31, 2015 03:01PM |
Re: Getting more speed out of Arduino Mega June 01, 2015 08:46AM |
TESKAn
Putting it all together, the code looks like this
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Getting more speed out of Arduino Mega June 01, 2015 12:51PM |
#define AUTOLEVEL_GRID_MULTI 1/AUTOLEVEL_GRIDTo get exact representation of this multiplier (that replaces one divide) AUTOLEVEL_GRID should be set to a power of 2, e.g. 8, 16, 32, 64...
void prepare_move() { // Replace function call // clamp_to_software_endstops(destination); if (min_software_endstops) { if (destination[X_AXIS] < min_pos[X_AXIS]) destination[X_AXIS] = min_pos[X_AXIS]; if (destination[Y_AXIS] < min_pos[Y_AXIS]) destination[Y_AXIS] = min_pos[Y_AXIS]; if (destination[Z_AXIS] < min_pos[Z_AXIS]) destination[Z_AXIS] = min_pos[Z_AXIS]; } if (max_software_endstops) { if (destination[X_AXIS] > max_pos[X_AXIS]) destination[X_AXIS] = max_pos[X_AXIS]; if (destination[Y_AXIS] > max_pos[Y_AXIS]) destination[Y_AXIS] = max_pos[Y_AXIS]; if (destination[Z_AXIS] > max_pos[Z_AXIS]) destination[Z_AXIS] = max_pos[Z_AXIS]; } previous_millis_cmd = millis(); #ifdef DELTA float difference[NUM_AXIS]; float addDistance[NUM_AXIS]; float fractions[NUM_AXIS]; difference[0] = destination[0] - current_position[0]; difference[1] = destination[1] - current_position[1]; difference[2] = destination[2] - current_position[2]; difference[3] = destination[3] - current_position[3]; float cartesian_mm = difference[X_AXIS] * difference[X_AXIS]; cartesian_mm += (difference[Y_AXIS] * difference[Y_AXIS]); cartesian_mm += (difference[Z_AXIS] * difference[Z_AXIS]); cartesian_mm = sqrt(cartesian_mm); if (cartesian_mm < 0.000001) { cartesian_mm = abs(difference[E_AXIS]); if(cartesian_mm < 0.000001) { return; } } // Using steps per mm makes much more sense float fTemp = cartesian_mm * 5; int steps = (int)fTemp; // At least one step // Calculate step and fraction if(0 == steps) { steps = 1; fractions[0] = difference[0]; fractions[1] = difference[1]; fractions[2] = difference[2]; fractions[3] = difference[3]; } else { fTemp = 1 / float(steps); fractions[0] = difference[0] * fTemp; fractions[1] = difference[1] * fTemp; fractions[2] = difference[2] * fTemp; fractions[3] = difference[3] * fTemp; } // For number of steps, for each step add one fraction // First, set initial destination to current position addDistance[0] = 0.0; addDistance[1] = 0.0; addDistance[2] = 0.0; addDistance[3] = 0.0; // Calculate feedrate*feedmultiply/60/100.0 // We use this in each for iteration float frfm = feedrate*feedmultiply/60/100.0; // Then add fraction for each segment step for (int s = 1; s <= steps; s++) { // Add step fraction addDistance[0] += fractions[0]; addDistance[1] += fractions[1]; addDistance[2] += fractions[2]; addDistance[3] += fractions[3]; // Add to destination destination[0] = current_position[0] + addDistance[0]; destination[1] = current_position[1] + addDistance[1]; destination[2] = current_position[2] + addDistance[2]; destination[3] = current_position[3] + addDistance[3]; // Calculate delta // X axis delta[X_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower1_x-destination[X_AXIS]; delta[X_AXIS] -= (fTemp * fTemp); fTemp = delta_tower1_y-destination[Y_AXIS]; delta[X_AXIS] -= (fTemp * fTemp); delta[X_AXIS] = sqrt(delta[X_AXIS]); delta[X_AXIS] += destination[Z_AXIS]; // Y axis delta[Y_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower2_x-destination[X_AXIS]; delta[Y_AXIS] -= (fTemp * fTemp); fTemp = delta_tower2_y-destination[Y_AXIS]; delta[Y_AXIS] -= (fTemp * fTemp); delta[Y_AXIS] = sqrt(delta[Y_AXIS]); delta[Y_AXIS] += destination[Z_AXIS]; // Z axis delta[Z_AXIS] = DELTA_DIAGONAL_ROD_2; fTemp = delta_tower3_x-destination[X_AXIS]; delta[Z_AXIS] -= (fTemp * fTemp); fTemp = delta_tower3_y-destination[Y_AXIS]; delta[Z_AXIS] -= (fTemp * fTemp); delta[Z_AXIS] = sqrt(delta[Z_AXIS]); delta[Z_AXIS] += destination[Z_AXIS]; //***************************************************************** // Comment this part out if you don't have auto bed leveling // Adjust delta float grid_x = destination[X_AXIS] * AUTOLEVEL_GRID_MULTI;// / AUTOLEVEL_GRID; if(2.999 < grid_x) grid_x = 2.999; else if(-2.999 > grid_x) grid_x = -2.999; float grid_y = destination[Y_AXIS] * AUTOLEVEL_GRID_MULTI;// / AUTOLEVEL_GRID; if(2.999 < grid_y) grid_y = 2.999; else if(-2.999 > grid_y) grid_y = -2.999; int floor_x = floor(grid_x); int floor_y = floor(grid_y); float ratio_x = grid_x - floor_x; float ratio_y = grid_y - floor_y; float z1 = bed_level[floor_x+3][floor_y+3]; float z2 = bed_level[floor_x+3][floor_y+4]; float z3 = bed_level[floor_x+4][floor_y+3]; float z4 = bed_level[floor_x+4][floor_y+4]; float left = (1-ratio_y)*z1 + ratio_y*z2; float right = (1-ratio_y)*z3 + ratio_y*z4; float offset = (1-ratio_x)*left + ratio_x*right; delta[X_AXIS] += offset; delta[Y_AXIS] += offset; delta[Z_AXIS] += offset; //***************************************************************** // End of comment plan_buffer_line(delta[X_AXIS], delta[Y_AXIS], delta[Z_AXIS], destination[E_AXIS], frfm, active_extruder); } #else #ifdef DUAL_X_CARRIAGE if (active_extruder_parked) { if (dual_x_carriage_mode == DXC_DUPLICATION_MODE && active_extruder == 0) { // move duplicate extruder into correct duplication position. plan_set_position(inactive_extruder_x_pos, current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]); plan_buffer_line(current_position[X_AXIS] + duplicate_extruder_x_offset, current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], max_feedrate[X_AXIS], 1); plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]); st_synchronize(); extruder_duplication_enabled = true; active_extruder_parked = false; } else if (dual_x_carriage_mode == DXC_AUTO_PARK_MODE) // handle unparking of head { if (current_position[E_AXIS] == destination[E_AXIS]) { // this is a travel move - skit it but keep track of current position (so that it can later // be used as start of first non-travel move) if (delayed_move_time != 0xFFFFFFFFUL) { memcpy(current_position, destination, sizeof(current_position)); if (destination[Z_AXIS] > raised_parked_position[Z_AXIS]) raised_parked_position[Z_AXIS] = destination[Z_AXIS]; delayed_move_time = millis(); return; } } delayed_move_time = 0; // unpark extruder: 1) raise, 2) move into starting XY position, 3) lower plan_buffer_line(raised_parked_position[X_AXIS], raised_parked_position[Y_AXIS], raised_parked_position[Z_AXIS], current_position[E_AXIS], max_feedrate[Z_AXIS], active_extruder); plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], raised_parked_position[Z_AXIS], current_position[E_AXIS], min(max_feedrate[X_AXIS],max_feedrate[Y_AXIS]), active_extruder); plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS], max_feedrate[Z_AXIS], active_extruder); active_extruder_parked = false; } } #endif //DUAL_X_CARRIAGE // Do not use feedmultiply for E or Z only moves if( (current_position[X_AXIS] == destination [X_AXIS]) && (current_position[Y_AXIS] == destination [Y_AXIS])) { plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], feedrate/60, active_extruder); } else { plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], feedrate*feedmultiply/60/100.0, active_extruder); } #endif //else DELTA for(int8_t i=0; i < NUM_AXIS; i++) { current_position = destination; } }
Re: Getting more speed out of Arduino Mega June 15, 2015 05:57PM |
Traumflug
TESKAn
Looks like you've put a lot of effort into what Teacup Firmware does for years already: looking at the details, measuring the results. Teacup even has precise measurement tools, which leads to kind of regression testing regarding performance:
[reprap.org]
P.S.: I just recognize the above might sound snobbish. Wasn't meant this way.
Re: Getting more speed out of Arduino Mega June 20, 2015 06:25AM |
thetazzbot
In particular I don't see support yet for the RepRapDiscount Full LCD with SD Card. Multiple extruders/Heaters/Thermistors/Fans? Can it utilize 100% the features of a basic RAMPS board?
Re: Getting more speed out of Arduino Mega June 23, 2015 01:08PM |
Traumflug
thetazzbot
Number of heaters and temp sensors only limited by the number of available pins. And you might find out that it's easier to add redundant stuff like displays, than getting the movement preparation and stepping algorithm up to perfection.
Re: Getting more speed out of Arduino Mega June 23, 2015 01:58PM |
Re: Getting more speed out of Arduino Mega June 24, 2015 03:01AM |
Re: Getting more speed out of Arduino Mega June 24, 2015 03:28AM |
Re: Getting more speed out of Arduino Mega June 24, 2015 06:02AM |
thetazzbot
I.e. who approves the pull requests?
Re: Getting more speed out of Arduino Mega June 24, 2015 08:34AM |
TESKAn
You are correct. Cartesian "core" is already pretty optimized as it uses GRBL project, also G code is already in cartesian so you don't have to do any expensive calculations to get from G code to stepper movements.
TESKAn
Deltas, on the other hand, have to turn each X/Y move into a series of short moves (in my code into 0.2 mm moves) because as you traverse lets say from -100 to +100 on X axis, it is not like on cartesian where you just command X axis stepper to move, you have to command all three steppers to move and not in one single move, but a series of smaller moves to move end effector in a straight line.
So where you have a single move on cartesian machine, you have hundreds of small moves on a delta machine and for each move you have to calculate for square roots and a bunch of other operations to get where you want to. And if you can save half the time on each short move, then it adds up.
Re: Getting more speed out of Arduino Mega June 24, 2015 08:43AM |
Traumflug
I consider it to be a myth that one can simply take such pull requests as-is. Most of them break other code, other platforms or are simply done only up to the "it works for me" state of the particular developer. Maybe Marlin is in its current state because it accepted such code.
dc42
TESKAn
That's not the only way of doing it. RepRapFirmware doesn't segment long moves at all. Instead it calculates the step times for a delta directly by solving the equations of motion.
