Edited [Kossel Mini] ABL not working on Marlin1.1.0RC2 probing out of printbed
October 28, 2015 08:44AM
So i guess i found out something.
For the probe to work i have to disable the X_MIN and Y_MIN endstops in the pins_RAMPS_13.h
#define X_MIN_PIN           -1
#define Y_MIN_PIN          -1
Now i got a different Problem.
When i G29 with the Probe deployed, it works with no problems.
If i G29 with the Probe not deployed, he is deploying it, moving slowly toward the mid and then tries to probe from that position (and takes this position as the bottom left point.
Attention: OP-Paint-Skillz
OLD: hi guys,
(this is a repost from another forum. i hope it fits here better)
i guess this is just a configuration issue, but i have no idea whats wrong.
I wanted to update to Marlin 1.1.0RC2 and diffed the configuration.h and configuration_adv,h.
Now when i try to autolevel my bed with G29 i get the error:
>>> G29
SENDING:G29
G29 Auto Bed Leveling
?Probe (F)ront position out of range.
I don't know if the probing area is set up correct. Just used the values that worked for my old Marlin version.
Edit:
Also, with some other settings i don't remember right now, after probe deploy the head drove out of the printing area (to the right).
My config (shortened):
configuration.h:
#define DELTA
#if ENABLED(DELTA)
// Make delta curves from many straight lines (linear interpolation).
// This is a trade-off between visible corners (not enough segments)
// and processor overload (too many expensive sqrt calls).
#define DELTA_SEGMENTS_PER_SECOND 200
// NOTE NB all values for DELTA_* values MUST be floating point, so always have a decimal point in them
// Center-to-center distance of the holes in the diagonal push rods.
#define DELTA_DIAGONAL_ROD 214.0 // mm
// Horizontal offset from middle of printer to smooth rod center.
#define DELTA_SMOOTH_ROD_OFFSET 145.0 // mm
// Horizontal offset of the universal joints on the end effector.
#define DELTA_EFFECTOR_OFFSET 19.9 // mm
// Horizontal offset of the universal joints on the carriages.
#define DELTA_CARRIAGE_OFFSET 19.5 // mm
// Horizontal distance bridged by diagonal push rods when effector is centered.
#define DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET)
// Print surface diameter/2 minus unreachable space (avoid collisions with vertical towers).
#define DELTA_PRINTABLE_RADIUS 95
#endif
const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_PROBE_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
//#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS // Deltas only use min endstops for probing.
//============================ Bed Auto Leveling ============================
// @section bedlevel
#define AUTO_BED_LEVELING_FEATURE // Delete the comment to enable (remove // at the start of the line)
//#define DEBUG_LEVELING_FEATURE
//#define Z_MIN_PROBE_REPEATABILITY_TEST  // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled.
#if ENABLED(AUTO_BED_LEVELING_FEATURE)
// There are 2 different ways to specify probing locations:
// - "grid" mode
//   Probe several points in a rectangular grid.
//   You specify the rectangle and the density of sample points.
//   This mode is preferred because there are more measurements.
// - "3-point" mode
//   Probe 3 arbitrary points on the bed (that aren't colinear)
//   You specify the XY coordinates of all 3 points.
// Enable this to sample the bed in a grid (least squares solution).
// Note: this feature generates 10KB extra code size.
#define AUTO_BED_LEVELING_GRID  // Deltas only support grid mode.
#if ENABLED(AUTO_BED_LEVELING_GRID)
// set the rectangle in which to probe
  #define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS - 10)
  #define LEFT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
  #define RIGHT_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
  #define FRONT_PROBE_BED_POSITION -DELTA_PROBABLE_RADIUS
  #define BACK_PROBE_BED_POSITION DELTA_PROBABLE_RADIUS
//#define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS-20)   //MR: Changed from (DELTA_PRINTABLE_RADIUS-10)
//#define LEFT_PROBE_BED_POSITION (10-DELTA_PROBABLE_RADIUS)  //MR: Changed from -DELTA_PROBABLE_RADIUS
//#define RIGHT_PROBE_BED_POSITION (DELTA_PROBABLE_RADIUS-10) //MR: Changed from DELTA_PROBABLE_RADIUS
//#define BACK_PROBE_BED_POSITION (DELTA_PROBABLE_RADIUS-10)  //MR: Changed from DELTA_PROBABLE_RADIUS
//#define FRONT_PROBE_BED_POSITION (10-DELTA_PROBABLE_RADIUS) //MR: Changed from -DELTA_PROBABLE_RADIUS
#define MIN_PROBE_EDGE 10 // The Z probe square sides can be no smaller than this.
// Non-linear bed leveling will be used.
// Compensate by interpolating between the nearest four Z probe values for each point.
// Useful for deltas where the print surface may appear like a bowl or dome shape.
// Works best with ACCURATE_BED_LEVELING_POINTS 5 or higher.
#define AUTO_BED_LEVELING_GRID_POINTS 2
#else  // !AUTO_BED_LEVELING_GRID
// Arbitrary points to probe.
// A simple cross-product is used to estimate the plane of the bed.
      #define ABL_PROBE_PT_1_X 15
      #define ABL_PROBE_PT_1_Y 180
      #define ABL_PROBE_PT_2_X 15
      #define ABL_PROBE_PT_2_Y 20
      #define ABL_PROBE_PT_3_X 170
      #define ABL_PROBE_PT_3_Y 20
      #define ABL_PROBE_PT_1_X 0
      #define ABL_PROBE_PT_1_Y 70
      #define ABL_PROBE_PT_2_X -60
      #define ABL_PROBE_PT_2_Y -35
      #define ABL_PROBE_PT_3_X 60
      #define ABL_PROBE_PT_3_Y -35
#endif // AUTO_BED_LEVELING_GRID
// Offsets to the Z probe relative to the nozzle tip.
// X and Y offsets must be integers.
#define X_PROBE_OFFSET_FROM_EXTRUDER 0.0   //MR: Changed from 3.5
#define Y_PROBE_OFFSET_FROM_EXTRUDER 16    //MR: Changed from 17
#define Z_PROBE_OFFSET_FROM_EXTRUDER -3.45  // Z probe to nozzle Z offset: -below (always!)
#define Z_RAISE_BEFORE_HOMING 4      // (in mm) Raise Z axis before homing (G28) for Z probe clearance.
// Be sure you have this distance over your Z_MAX_POS in case.
#define XY_TRAVEL_SPEED 1000         // X and Y axis travel speed between probes, in mm/min.
#define Z_RAISE_BEFORE_PROBING 15   // How much the Z axis will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 2  // How much the Z axis will be raised when traveling from between next probing points
#define Z_RAISE_AFTER_PROBING 50    // How much the Z axis will be raised after the last probing point.
//#define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10" // These commands will be executed in the end of G29 routine.
// Useful to retract a deployable Z probe.
//#define Z_PROBE_SLED // Turn on if you have a Z probe mounted on a sled like those designed by Charles Bell.
//#define SLED_DOCKING_OFFSET 5 // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// Allen key retractable z-probe as seen on many Kossel delta printers - [reprap.org]
// Deploys by touching z-axis belt. Retracts by pushing the probe down. Uses Z_MIN_PIN.
#define Z_PROBE_ALLEN_KEY
#if ENABLED(Z_PROBE_ALLEN_KEY)
// 2 or 3 sets of coordinates for deploying and retracting the spring loaded touch probe on G29,
// if servo actuated touch probe is not defined. Uncomment as appropriate for your printer/probe.
// Kossel Mini
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_X 30.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_Y DELTA_PRINTABLE_RADIUS
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_Z 100.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_1_FEEDRATE XY_TRAVEL_SPEED
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_X 5.0 // 0
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_Y DELTA_PRINTABLE_RADIUS
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_Z 100.0
#define Z_PROBE_ALLEN_KEY_DEPLOY_2_FEEDRATE (XY_TRAVEL_SPEED/10)
#define Z_PROBE_ALLEN_KEY_STOW_DEPTH 15
// Move the probe into position
#define Z_PROBE_ALLEN_KEY_STOW_1_X -21 // -64
#define Z_PROBE_ALLEN_KEY_STOW_1_Y 93 // 56
#define Z_PROBE_ALLEN_KEY_STOW_1_Z 24 // 23
#define Z_PROBE_ALLEN_KEY_STOW_1_FEEDRATE XY_TRAVEL_SPEED
// Move the nozzle down further to push the probe into retracted position.
#define Z_PROBE_ALLEN_KEY_STOW_2_X  Z_PROBE_ALLEN_KEY_STOW_1_X
#define Z_PROBE_ALLEN_KEY_STOW_2_Y  Z_PROBE_ALLEN_KEY_STOW_1_Y
#define Z_PROBE_ALLEN_KEY_STOW_2_Z  (Z_PROBE_ALLEN_KEY_STOW_1_Z-Z_PROBE_ALLEN_KEY_STOW_DEPTH)
#define Z_PROBE_ALLEN_KEY_STOW_2_FEEDRATE (XY_TRAVEL_SPEED/10)
// Raise things back up slightly so we don't bump into anything
#define Z_PROBE_ALLEN_KEY_STOW_3_X  Z_PROBE_ALLEN_KEY_STOW_2_X
#define Z_PROBE_ALLEN_KEY_STOW_3_Y  Z_PROBE_ALLEN_KEY_STOW_2_Y
#define Z_PROBE_ALLEN_KEY_STOW_3_Z  (Z_PROBE_ALLEN_KEY_STOW_1_Z+Z_PROBE_ALLEN_KEY_STOW_DEPTH)
#define Z_PROBE_ALLEN_KEY_STOW_3_FEEDRATE (XY_TRAVEL_SPEED/2)
#endif
// If you have enabled the bed auto leveling and are using the same Z probe for Z homing,
// it is highly recommended you let this Z_SAFE_HOMING enabled!!!
#define Z_SAFE_HOMING   // This feature is meant to avoid Z homing with Z probe outside the bed area.
// When defined, it will:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers timeout, it will need X and Y homing again before Z homing.
// - Position the Z probe in a defined XY point before Z Homing when homing all axis (G28).
// - Block Z homing only when the Z probe is outside bed area.
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2)    // X point for Z homing when homing all axis (G28).
#define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2)    // Y point for Z homing when homing all axis (G28).
#endif
// Support for a dedicated Z probe endstop separate from the Z min endstop.
// If you would like to use both a Z probe and a Z min endstop together,
// uncomment #define Z_MIN_PROBE_ENDSTOP and read the instructions below.
// If you still want to use the Z min endstop for homing, disable Z_SAFE_HOMING above.
// Example: To park the head outside the bed area when homing with G28.
// WARNING:
// The Z min endstop will need to set properly as it would without a Z probe
// to prevent head crashes and premature stopping during a print.
// To use a separate Z probe endstop, you must have a Z_MIN_PROBE_PIN
// defined in the pins_XXXXX.h file for your control board.
// If you are using a servo based Z probe, you will need to enable NUM_SERVOS,
// Z_ENDSTOP_SERVO_NR and SERVO_ENDSTOP_ANGLES in the R/C SERVO support below.
// RAMPS 1.3/1.4 boards may be able to use the 5V, Ground and the D32 pin
// in the Aux 4 section of the RAMPS board. Use 5V for powered sensors,
// otherwise connect to ground and D32 for normally closed configuration
// and 5V and D32 for normally open configurations.
// Normally closed configuration is advised and assumed.
// The D32 pin in Aux 4 on RAMPS maps to the Arduino D32 pin.
// Z_MIN_PROBE_PIN is setting the pin to use on the Arduino.
// Since the D32 pin on the RAMPS maps to D32 on Arduino, this works.
// D32 is currently selected in the RAMPS 1.3/1.4 pin file.
// All other boards will need changes to the respective pins_XXXXX.h file.
// WARNING:
// Setting the wrong pin may have unexpected and potentially disastrous outcomes.
// Use with caution and do your homework.
#endif // AUTO_BED_LEVELING_FEATURE
If you could help me, that would be great smiling smiley
-Culain
Edited 2 time(s). Last edit at 10/28/2015 10:40AM by Culain.
Re: Edited [Kossel Mini] ABL not working on Marlin1.1.0RC2 probing out of printbed
November 17, 2015 09:10AM
Decrease your DELTA_PROBABLE_RADIUS.
That, combined with your Y_PROBE_OFFSET_FROM_EXTRUDER means that you would be probing outside the bed.
Replace
with
#define DELTA_PROBABLE_RADIUS (DELTA_PRINTABLE_RADIUS - 20)
That at least will get your delta probing, but you'll still have the issue of probing outside the bed like me *sigh*
Edited 1 time(s). Last edit at 11/17/2015 09:12AM by nebbian.
November 17, 2015 09:37AM
OK what you need to do is this:
Modify this line to be 50:
#define Z_RAISE_BEFORE_PROBING 50
The solution was posted here:
[github.com]
