Understanding Marlin March 29, 2016 01:56AM |
void get_command(){
omitted lines 416-521
#ifdef SDSUPPORT
if(!card.sdprinting || serial_count != 0){
return;
while( !card.eof() && buflen < BUFSIZE) {
int16_t n=card.get();
serial_char = (char)n;
if(serial_char == '\n' ||
serial_char == '\r' ||
(serial_char == ':' && comment_mode == false) ||
serial_count >= (MAX_CMD_SIZE - 1)||n==-1)
if(card.eof()){
SERIAL_PROTOCOLLNPGM(MSG_FILE_PRINTED);
stoptime=millis();
char time[30];
unsigned long t=(stoptime-starttime)/1000;
int hours, minutes;
minutes=(t/60)%60;
hours=t/60/60;
sprintf_P(time, PSTR("%i hours %i minutes"),hours, minutes);
SERIAL_ECHO_START;
SERIAL_ECHOLN(time);
lcd_setstatus(time);
card.printingHasFinished();
card.checkautostart(true);
if(!serial_count)
comment_mode = false; //for new command
return; //if empty line
cmdbuffer[bufindw][serial_count] = 0; //terminate string
// if(!comment_mode){
fromsd[bufindw] = true;
buflen += 1;
bufindw = (bufindw + 1)%BUFSIZE;
serial_count = 0; //clear buffer
else
if(serial_char == ';') comment_mode = true;
if(!comment_mode) cmdbuffer[bufindw][serial_count++] = serial_char;
#endif //SDSUPPORT
return;
if serial_count is not zero, the code kicks us out of "void get_command()" and back into "void loop()", so we know if we got past this point that serial_count is equal to 0.
then another if statement, line 529:
if we don't pass this conditionals for this if statement we are sent down to lines 566-567
where serial_count gets advanced by 1 (serial_count++) and then used in the cmdbuffer array.
if(!serial_count)
so if serial_count equals 0, it will pass this conditional and hit the "return;" that will kick us back out to "void loop()"|
Re: Understanding Marlin April 16, 2016 02:17PM |
Jrodenba
then "void get_command()" ends and we are returned to "void loop()", but serial_count is now greater than 0, so the next time "void get_command()" is called it will automatically trigger the "return" on line 524
Re: Understanding Marlin April 17, 2016 09:11PM |
