Marlin 1.0.1-RC6 to 3KU Delta,problrm with inductive board sensor & Extruder Settings (HELP) July 15, 2016 07:37PM |
Re: Marlin 1.0.1-RC6 to 3KU Delta,problrm with inductive board sensor & Extruder Settings (HELP) July 16, 2016 01:01PM |
Re: Marlin 1.0.1-RC6 to 3KU Delta,problrm with inductive board sensor & Extruder Settings (HELP) July 17, 2016 03:03AM |
stephenrc
If you have the EEPROM enabled, you need to send gcode M502, followed by M500 to get Marlin to use the values in configuration.h.
You inductive sensor isn't going close enough to 0vdc from 5vdc to trigger a change. Another way is to have the sensor trigger a relay instead of using a resister network.
Re: Marlin 1.0.1-RC6 to 3KU Delta,problrm with inductive board sensor & Extruder Settings (HELP) July 17, 2016 08:17PM |
