emt
Have I got Teacup Firmware config.h wrong?
January 21, 2011 09:50AM
Hi
I am having another attempt at using 5DA on a Mega 1280.
My heater is on mega pin digital 3.
I have therefore filled in the structure as follows
struct {
volatile uint8_t *heater_port;
uint8_t heater_pin;
volatile uint8_t *heater_pwm;
} heaters[NUM_HEATERS] =
// port pin pwm
{ &PORTE, PINE5, &OC3C },
make produces this error:-
In file included from heater.c:15:
config.h:300: error: ‘DIO3’ undeclared here (not in a function)
Have I put the incorrect data in the structure or is there a problem elsewhere?
[Edit: Changed name to "Teacup Firmware" for the purposes of not confusing folk, after irc discussion. --Sebastien]
Edited 3 time(s). Last edit at 02/22/2011 02:13AM by SebastienBailard.
Regards
Ian
Re: Have I got FiveD on Arduino config.h wrong?
January 22, 2011 03:22AM
Try OCR3C smiling smiley
Wooden Mendel
Teacup Firmware
emt
January 22, 2011 05:44AM
Many thanks.
I was blindly copying the remarks in config.h, new to C and Linux.
I now get a warning:-
config.h:300: warning: initialisation from incompatible pointer type
Should I worry about this?
I have attached modified appendix data for config.h.dist
Regards
Ian
open | download - AppendixA.txt (3.1 KB)
January 23, 2011 07:07PM
You still need the ampersand on both ports, just not the pin
Wooden Mendel
Teacup Firmware
emt
January 24, 2011 06:59AM
Hi
Sorry for the hassle of this. I really appreciate the work that you are doing.
I thought I had the ampersands correct.
I attach my config.h file.
I appear to have every thing working correctly except the heater.........
Regards
Ian
open | download - config.h (17.9 KB)
January 24, 2011 08:46PM
ah, I see your problem, timer 3 is a 16-bit timer, whereas the heater is expecting an 8-bit register. Provide &OCR3CL, but you'll have to change the initialisation in mendel.c too. We want fast pwm, 8 bit, which according to the datasheet requires the following changes:
diff --git a/mendel.c b/mendel.c
index e36387d..a05909b 100644
--- a/mendel.c
+++ b/mendel.c
@@ -82,24 +82,24 @@ void io_init(void) {
        OCR2B = 0;
        #ifdef  TCCR3A
-               TCCR3A = MASK(WGM31) | MASK(WGM30);
-               TCCR3B = MASK(CS30);
+               TCCR3A = MASK(WGM30);
+               TCCR3B = MASK(WGM32) | MASK(CS30);
                TIMSK3 = 0;
                OCR3A = 0;
                OCR3B = 0;
        #endif
        #ifdef  TCCR4A
-               TCCR4A = MASK(WGM41) | MASK(WGM40);
-               TCCR4B = MASK(CS40);
+               TCCR4A = MASK(WGM40);
+               TCCR4B = MASK(WGM42) | MASK(CS40);
                TIMSK4 = 0;
                OCR4A = 0;
                OCR4B = 0;
        #endif
        #ifdef  TCCR5A
-               TCCR5A = MASK(WGM51) | MASK(WGM50);
-               TCCR5B = MASK(CS50);
+               TCCR5A = MASK(WGM50);
+               TCCR5B = MASK(WGM52) | MASK(CS50);
                TIMSK5 = 0;
                OCR5A = 0;
                OCR5B = 0;
This is from me copying+pasting initialisations for smaller timers and not testing on a 'mega. I'll push this to the repository when I've done some documentation.
One other thing: the heater index for your temp sensor should be set to 0 if you want closed-loop control!
255 (actually anything >= NUM_HEATERS) means no associated heater, just a lone temp sensor.
Wooden Mendel
Teacup Firmware
emt
January 25, 2011 12:20PM
Many thanks again.
I have made the changes you show.
I also altered heater index to 0
Make now compiles cleanly.
I can control all the axes from miniterm and get the response I expect. The thermistor is responding to heat from a hot air gun. The only thing not working at the moment is the extruder heater. The command I use is M104 Snnn.
I guess I still have something wrong in the config.h or makefile. I know the electronics are OK as the heater works with the standard firmware.
Will debug help me and how do I turn it on? My makefile contains DEFS = "-DDEBUG=1"
Do I have to change the number to get more information?
Regards
Ian
January 25, 2011 05:56PM
I think debug can be defined in your config. Once defined, you can turn various bits on and off with some M-codes. I think DEBUG_PID will help you with your heater stuff. Probably needs to be documented a bit better, I'm sure you'll figure it out until then
Wooden Mendel
Teacup Firmware
January 26, 2011 01:02PM
I just went through this exorcise and what i found was the eeprom settings fro PID were not getting set as described in the other thread. I currently have to manually issue the proper M codes to set the PID values and then my Heater controls began functioning correctly.
-trout
emt
January 27, 2011 12:46PM
Thanks Architect
I can't find any reference to PID not setting in the other thread. Can you give me a link please. What would be a good set of values to start with and what can the range of values be? I am right that these are set with M130 Snnn for P and M131 Snnn for I etc.
Regards
Ian
January 27, 2011 02:47PM
Architect Wrote:
> I currently
> -trout
Do you have to do this every time you power up your Arduino? I had this porblem too, but once I had set the PID values I used m134 (I think) to write the values to the eeprom. Now the setting remian through a power cycle.
Start here, it carries on for a few posts and there may be some other posts in between but all the info is there.
Edited 1 time(s). Last edit at 01/27/2011 07:05PM by spaztik.
February 02, 2011 08:30AM
hello
I'va a question about config.h
DEFINE_TEMP_SENSOR(extruder,  TT_INTERCOM,    0,           255)
my thermistor is connected to Analog pin 1, closed loop with heater defined on
#define DEFINE_HEATER(extruder, PORTD, PIND6, OCR0A)
I've try both :
#define DEFINE_TEMP_SENSOR(extruder,TT_THERMISTOR,AI01,0)
and
#define DEFINE_TEMP_SENSOR(extruder,TT_THERMISTOR,1,0)
I allays get an error compilling
"config.h:248:52: erreur: « 0 » peut ne pas apparaître parmi les paramètres de macros"
or
"config.h:248:52: erreur: « 1 » peut ne pas apparaître parmi les paramètres de macros"
(approx translation of the error message :
..."1" can't appears in parameters of macro"
I don't really understand :
-the pin is the number of termistor pin, in wich form ?
-the name 'extruder' is an exemple or is usable directly ?
thanks
about setting correct values to PID
the Ziegler Nichols_method is quite simple
emt
February 02, 2011 11:18AM
Spaztic
Many belated thanks, been off line the last few days.
Regards
Ian
