Re: Teacup Firmware replicatorG & Skeinforge April 16, 2011 07:55PM |
Re: Teacup Firmware replicatorG & Skeinforge April 17, 2011 02:11AM |
sersendf_P(PSTR("\nT:%u.%u"), temp_sensors_runtime[index].last_read_temp >> 2, c);
Re: Teacup Firmware replicatorG & Skeinforge April 17, 2011 03:07AM |
Re: Teacup Firmware replicatorG & Skeinforge April 17, 2011 06:23AM |
Re: Teacup Firmware replicatorG & Skeinforge April 17, 2011 12:36PM |
Re: Teacup Firmware replicatorG & Skeinforge April 17, 2011 02:58PM |
Re: Teacup Firmware replicatorG & Skeinforge April 17, 2011 03:15PM |
Re: Teacup Firmware replicatorG & Skeinforge April 23, 2011 10:49PM |
Re: Teacup Firmware replicatorG & Skeinforge April 23, 2011 11:05PM |
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 03:02PM |
(beginning of start.txt) G21 (Metric FTW) G90 (Absolute Positioning) M104 S230 (preheat the extruder) M140 S100 (preheat the bed) G1 Z15 F70 G1 X-200 F800 G1 Y-200 F800 G92 X0 Y0 G1 Y75 F800 G1 Z-100 F70 G92 Z-2.35 G1 Z12 (Move to purge plate for warmup) M109 G92 E0 (Reset extruder position) G1 E5 F30(Extrude 500mm onto purge plate) G1 E4 F300 G1 X0 Y150 F4000 (wipe) G1 X20 Y150 G1 Z.2 F70 (G92 X0 Y0) G92 E0 (Reset extruder again for print) (end of start.txt)
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 03:07PM |
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 03:10PM |
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 07:06PM |
INFO: Sending: N9 T0 M105 *74 Apr 28, 2011 5:54:05 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: << t:35.00 Apr 28, 2011 5:54:05 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: << ok t:35.00 b:35.00 Apr 28, 2011 5:54:05 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: FW Accepted: N9 T0 M105 *74 Apr 28, 2011 5:54:06 PM replicatorg.drivers.reprap.RepRap5DDriver _sendCommand INFO: Sending: N10 T0 M105 *114 Apr 28, 2011 5:54:06 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: << t:32.00 Apr 28, 2011 5:54:06 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: << ok t:32.00 b:35.00 Apr 28, 2011 5:54:06 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: FW Accepted: N10 T0 M105 *114
INFO: FW Accepted: N9 T0 M105 *74 Apr 28, 2011 5:52:26 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: << t:34.25 b:28.50 Apr 28, 2011 5:52:27 PM replicatorg.drivers.reprap.RepRap5DDriver _sendCommand INFO: Sending: N10 T0 M105 *114 Apr 28, 2011 5:52:27 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: << ok Apr 28, 2011 5:52:27 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: FW Accepted: N10 T0 M105 *114 Apr 28, 2011 5:52:27 PM replicatorg.drivers.reprap.RepRap5DDriver serialByteReceivedEvent INFO: << t:27.75 b:24.0
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 07:42PM |
sliptonic
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 07:52PM |
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 08:01PM |
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 08:13PM |
--- gcode_process.c~ 2011-04-26 20:55:01.000000000 +1000 +++ gcode_process.c 2011-04-29 10:03:35.000000000 +1000 @@ -363,7 +363,8 @@ // M109- set temp and wait case 109: - temp_set(next_target.P, next_target.S); + if (next_target.seen_S) + temp_set(next_target.P, next_target.S); if (next_target.S) { power_on(); enable_heater();
Re: Teacup Firmware replicatorG & Skeinforge April 28, 2011 08:43PM |
sliptonic
Re: Teacup Firmware replicatorG & Skeinforge April 29, 2011 12:23PM |
Re: Teacup Firmware replicatorG & Skeinforge April 29, 2011 12:44PM |
[11:30:03] Building... [11:30:03] Estimating build time... [11:30:03] Loaded axis X: (Length: 205.0mm, max feedrate: 5000.0 mm/min, scale: 31.496 steps/mm) [11:30:03] Loaded axis Y: (Length: 195.0mm, max feedrate: 5000.0 mm/min, scale: 31.496 steps/mm) [11:30:03] Loaded axis Z: (Length: 140.0mm, max feedrate: 200.0 mm/min, scale: 1133.858 steps/mm) [11:30:04] Estimated build time is: 27 minutes [11:30:04] Beginning build. [11:30:04] Machine state changed to BUILDING [11:30:04] sending: N3 M114 *4 [11:30:04] Running warmup commands. [11:30:04] Running build. [11:30:04] sending: N4 G21 *62 [11:30:05] sending: N5 G90 *53 [11:30:05] sending: N6 M104 S230 *66 [11:30:05] sending: N7 M140 S100 *67 [11:30:05] sending: N8 G1 Z15.0 F70 *1 [11:30:05] sending: N9 G161 X0 *78 [11:30:05] Supports RC [11:30:19] sending: N10 G161 Y0 *119 [11:30:20] sending: N11 G92 X0 Y0 *3 [11:30:20] sending: N12 G1 Y75.0 F800 *0 [11:30:20] sending: N13 G161 Z0 F70 *22 [11:30:50] sending: N14 G92 Z-3 *99 [11:30:50] sending: N15 G1 Z12.0 *91 [11:30:50] sending: N16 G92 E0 *80 [11:31:01] sending: N17 M109 S220 *126 [11:31:01] sending: N18 G1 E5 F30 *4 [11:31:01] sending: N19 G1 E4 F300 *52 [11:31:01] sending: N20 G1 X0.0 Y150.0 F4000 *93 [11:31:01] sending: N21 G1 X20.0 Y150.0 *12 [11:31:01] sending: N22 G1 Z0.2 F70 *15 [11:31:01] sending: N23 G92 E0 *86
Re: Teacup Firmware replicatorG & Skeinforge April 29, 2011 12:45PM |
Re: Teacup Firmware replicatorG & Skeinforge April 29, 2011 03:31PM |
sliptonic
Re: Teacup Firmware replicatorG & Skeinforge April 29, 2011 04:49PM |
Re: Teacup Firmware replicatorG & Skeinforge April 29, 2011 08:47PM |
Re: Teacup Firmware replicatorG & Skeinforge April 29, 2011 09:16PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Teacup Firmware replicatorG & Skeinforge May 01, 2011 06:22PM |
Re: Teacup Firmware replicatorG & Skeinforge May 01, 2011 06:55PM |
Re: Teacup Firmware replicatorG & Skeinforge May 01, 2011 07:37PM |
Re: Teacup Firmware replicatorG & Skeinforge May 01, 2011 08:22PM |
Re: Teacup Firmware replicatorG & Skeinforge May 01, 2011 10:21PM |
