Re: LPC port of RepRapFirmware January 20, 2020 11:05AM |
Re: LPC port of RepRapFirmware January 21, 2020 06:55AM |
Re: LPC port of RepRapFirmware January 21, 2020 08:10AM |
Re: LPC port of RepRapFirmware January 21, 2020 08:20AM |
Admin Registered: 18 years ago Posts: 14,166 |
Re: LPC port of RepRapFirmware January 21, 2020 09:01AM |
Re: LPC port of RepRapFirmware February 18, 2020 04:07AM |
Re: LPC port of RepRapFirmware February 18, 2020 04:36AM |
Re: LPC port of RepRapFirmware February 18, 2020 05:30AM |
jay_s
There is no reason that I'm aware of that it wouldn't work, but I haven't seen any reports of anyone trying one either.
By all means try it but if it doesn't work, I would suggest looking at using RRF3 instead of RRF2.
This version is pretty much frozen now and won't have any further development carried out.
If you're using this with an MKS Sbase, I take it you are using the ethernet connection for control? There isn't currently a recent build of the ethernet version of RRF3 but I can look at doing one tonight for you.
Just be warned that you will have to make a number of changes to you config to make the move from RRF2 to RRF3.
Either look at generating a new config as reference using the configurator or change your config taking into account the changes required detailed here.
Also be aware that changes are required to your board.txt file. Examples can be found here
Re: LPC port of RepRapFirmware February 18, 2020 05:35AM |
MKSA
I currently stay with RRF 2 as it is "frozen" and currently does what I need. Will eventually move to RRF 3, just I don't want to get confused by other issues
Re: LPC port of RepRapFirmware February 18, 2020 06:37AM |
MKSA
Does this RRF version support this function and/or has someone used/tested it with a pulse generating sensor (https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_Technical_details).
I am using a digital Hall sensor 3144 and a magnet mounted on my extruder idler giving 6 pulses per turn (about one pulse per 7mm of filament.) and plan to connect it to one of the free endstop pin of a MKS SBASE 1.3.
Re: LPC port of RepRapFirmware February 18, 2020 09:19PM |
Re: LPC port of RepRapFirmware February 25, 2020 02:54AM |
jay_s
MKSA
No problem, just wanted to make sure you were fully informed.
I'm currently running the latest 3.01 RC1 on a printer mainly without issue.
I'm eagerly awaiting your feedback as to whether it works or not.
If and when you do decide to make the plunge to move to RRF3, we're here to support.
I've also started work on a wiki page to try ensure that all the steps required are documented where they differ from the official RRF instructions.
How do you find RRF2 currently? Which version of DWC are you using? What sort of machine are you running it on?
I use the crude MKS TFT32 or Pronterface. The machine started as a Geeetech Al Prusa. I thrown away everything but the motors and the Al frame I had to reinforce. Changed everything from the smallest bearing, not just the parts but the whole design, to the electronics. I wanted to test various solutions I could use on a better kinematic but so far keep it as is because I get good results.|
Re: LPC port of RepRapFirmware February 25, 2020 03:17AM |
Re: LPC port of RepRapFirmware February 25, 2020 03:53AM |
Re: LPC port of RepRapFirmware February 25, 2020 04:05AM |
Re: LPC port of RepRapFirmware March 05, 2020 10:05AM |
Re: LPC port of RepRapFirmware March 07, 2020 11:39AM |
Re: LPC port of RepRapFirmware March 07, 2020 12:06PM |
MKSA
@jay_s
Looks like this huge delay is due to how slow the scripts are transferred to the PC ???
Am I the only one facing this ?
Re: LPC port of RepRapFirmware March 07, 2020 03:25PM |
Re: LPC port of RepRapFirmware March 07, 2020 04:04PM |
jay_s
@MKSA
Sorry I haven't replied earlier.
I had this happen with one of my boards with it taking forever to show DWC.
You could try what sinned recommended and statically assign an IP address and see if that fixes the issue. I upgraded to RRF 3 (to match the rest of my machines) and the issue went away.
I don't think it's related to speed as the issue doesn't exist on RRF 3.
I suggest going the static IP address route and see if that fixes it
Re: LPC port of RepRapFirmware March 08, 2020 04:12PM |
Re: LPC port of RepRapFirmware March 08, 2020 04:28PM |
Re: LPC port of RepRapFirmware March 08, 2020 04:42PM |
jay_s
I've powered mine with 24v and had the issue of it taking a while to connect on the network. With RRF3, I don't get that issue. Once loaded it works fine.
It may need @sdavi to come in as I don't know what changes have been made in RRF between version 2 and 3.
@MKSA
If you like DWC, might be another reason to look at upgrading to RRF3.
Re: LPC port of RepRapFirmware March 08, 2020 04:59PM |
Re: LPC port of RepRapFirmware March 09, 2020 12:00AM |
Re: LPC port of RepRapFirmware March 09, 2020 05:31AM |
Re: LPC port of RepRapFirmware March 09, 2020 07:59AM |
Re: LPC port of RepRapFirmware March 09, 2020 08:04AM |
Re: LPC port of RepRapFirmware March 23, 2020 06:17AM |
jay_s
@sdavi
I definitely saw a difference in response times between RRF2 and RRF3 but I was using two different MKS boards.
I thought the slow down I saw was of a result of the board I used for RRF2 having a borked driver (amongst other things).
For me, on RRF2, it took about 5 minutes to load DWC. After that, everything was fine.
I have a spare MKS board and will do a comparison test between RRF2 and RRF3 this evening.
but once loaded all seems fine but sometime com errors then it reconnects. Upload of a 1 Megabyte file in 5s but cannot download it back or edit it ?|
Re: LPC port of RepRapFirmware April 10, 2020 11:32AM |
