Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 17, 2011 11:58AM |
brnrd
I have converted my electronics to RAMPS 1.2 and loaded the latest sprinter from github. I am printing SF 41 generated g-code with Repsnapper on the MacOS 10.5.8 at 115200 baud and it seems to be a good working combination. Last night I printed a part that took 6.5 hours successfully. But the rounded corners came out rough and the quality didn't look as good as prints that I was getting with Gen 3.
I have the Pololus set as follows: 1/16 steps for x and y, 1/2 steps on z and 1/8 steps on E. Printing at a feed rate of 30 mm/s, I can see that it doesn't go around arcs smoothly and it goes slower than at straight segments. The filament at curves comes out wavy instead of smooth. This is a sign that the Arduino is not getting the data fast enough when it makes short moves as it goes around arcs. Is there a way to fix this bottleneck in the Repsnapper and/or firmware setting? Can be fixed with an SD-card? Is an SD card kit available somewhere?
jcabrer
You are probably using Oozebane. Turn that off. I get silky smooth rounds using Sprinter.
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 17, 2011 01:35PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 19, 2011 05:58AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 19, 2011 07:41AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 19, 2011 07:47AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 19, 2011 09:04PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 21, 2011 02:45AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 21, 2011 05:44AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 21, 2011 05:56AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 21, 2011 04:07PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 21, 2011 07:40PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 27, 2011 09:44PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 29, 2011 12:56PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 29, 2011 11:15PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 30, 2011 03:27AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 30, 2011 03:28AM |
send.py strips out the white space
Why the hell would send.py do that?
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 30, 2011 04:09AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 30, 2011 11:56AM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 30, 2011 12:07PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration June 30, 2011 01:30PM |
Re: Sprinter (was Klimentkip/caruKlip) with acceleration July 11, 2011 09:10PM |
