Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 06, 2020 03:14PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 06, 2020 04:09PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 06, 2020 05:47PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 06, 2020 05:50PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 02:52AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 02:57AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 03:04AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 03:33AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 03:40AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 03:41AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 04:17AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 04:37AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 06:01AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 08:14AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 01:56PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 02:29PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 03:36PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 07, 2020 03:47PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 08, 2020 03:40AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 08, 2020 04:03AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 08, 2020 11:25AM |
jay_s
There was someone that DC42 knows who was supposed to be working on just that. Not heard anything about it for a few months though.
@DC42 any update on the STM32 port?
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 10, 2020 09:21PM |
dc42
Someone recently enquired when I was likely to add TMC2209 stall detection support to the TMC22xx driver in RRF, although I haven't found the original post. I've now added stall detection and configuration to the version of that driver in the Duet3Expansion project. It may be a little while before I port it over to the driver in RepRapFirmware (from which it was derived) because there isn't yet a Duet main board with TMC2209 drivers; but if someone else wants to port the changes across, it shouldn't be hard to do. The main difference between the two drivers is that the one in Duet3Expansion uses a separate FreeRTOS task to do the UART communication.
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 12:46AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 01:32AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 01:46AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 01:53AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 01:56AM |
Then download and install make. Use the “complete package except sources” version. Once installed you will need to add the location of the bin folder that is installed to your windows path environment setting. While there also add the location of mkdir.exe which will have been installed with git. It can be found in the usr/bin folder where git is installed. Once thats done, close VSCode and then reopen it.
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 02:26AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 03:06AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 03:38AM |
