Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 04:04AM |
jay_s
All,
The wiki has been updated.
The SKR instructions have been split into wifi and SBC. The stepper.numSmartDrivers in board.txt will be available when the next build is released. The code is already present if you want to create your own build
MKS Sbase instructions have been uploaded. Wifi instructions have been included which detail the hardware mod. The firmware to support this will be available when the next build is released. The code is already present if you want to create your own build
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 04:14AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 04:18AM |
PCR
Thank you for the hard work! My first Prototype PCB for the SKR is coming this week! The next Revision is also ready. But it is really hard to finde some female idc connectors for soldering!
What´s better? 2 Cables or a thing which directly plugs into the SKR Board.
I tested the TFT35V2 and TFT35V3 Displays from Bigtreetech with the Custom Firmware from a user here in the Forum! Works perfect. A PanelDue i will try this week. If you want i can write a little wiki!
Best
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 04:57AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 05:05AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 06:09AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 06:26AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 06:30AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 06:37AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 06:39AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 06:45AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 06:47AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 06:50AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 07:09AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 07:12AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 04:25PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 04:27PM |
DrDitto
tHANKS
SKR V1.3
12864 BIG ONE
aND JUST SEE BLACK SCREEN
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 05:21PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 09:54PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 11, 2020 11:05PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 03:29AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 03:41AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 03:42AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 03:43AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 03:47AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 06:40AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 11:31AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 11:52AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 12, 2020 11:58AM |
