Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 14, 2020 12:35PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 14, 2020 03:40PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 14, 2020 03:46PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 14, 2020 04:27PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 15, 2020 03:45AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 15, 2020 03:47AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 15, 2020 04:14AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 15, 2020 04:38AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 15, 2020 02:34PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 15, 2020 05:59PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 12:10AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 01:33AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 02:03AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 02:15AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 02:32AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 02:46AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 03:10AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 03:13AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 04:32AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 04:51AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 04:59AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 05:23AM |
M122 === Diagnostics === RepRapFirmware for LPC176x based Boards (biquskr_1.3) version 3.1.0 running on LPC176x at 100Mhz Used output buffers: 3 of 16 (10 max) === RTOS === Static ram: 3876 Dynamic Memory (RTOS Heap 5): 3008 free, 2984 never used Exception stack ram used: 304 Never used ram: 380 Tasks: NETWORK(ready,248) HEAT(blocked,1400) MAIN(running,1460) IDLE(ready,80) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:11 ago, cause: [power up][reset button] LPC Flash Slot[15]: Last software reset at 2020-05-16 11:20, reason: User, spinning module GCodes, available RAM 380 bytes (slot 0) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0442d000 BFAR 0xe000ed38 SP 0x00000001 Task MAIN Stack: 10002da8 2007c1dc 000108c9 00000000 00023243 2007da2c 000003e7 2007d7a4 00005f95 20083110 10002da8 Error status: 0 Driver 0: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 22 Driver 1: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 22 Driver 2: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 21 Driver 3: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 21 Driver 4: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 21 Date/time: 2020-05-16 11:22:33 Slowest loop: 3.58ms; fastest: 0.31ms === Storage === Free file entries: 4 SD card 0 detected SD card longest read time 1.4ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0, FreeDm: 100, MinFreeDm: 100, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === DDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = -1, chamberHeaters = -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 25.71ms; fastest: 0.00ms Responder states: HTTP(2) HTTP(0) HTTP sessions: 1 of 2 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23L263-302 WiFi MAC address ec:fa:bc:c5:11:72 WiFi Vcc 64.00, reset reason Unknown WiFi flash size 4194304, free heap 38448 WiFi IP address 192.168.178.25 WiFi signal strength -59dBm, reconnections 0, sleep mode modem Socket states: 4 0
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 05:26AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 09:50AM |
WiFi signal strength -48dBm, reconnections 0, sleep mode modemI rebooted it and the second time I got
WiFi signal strength -92dBm, reconnections 0, sleep mode modem
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 12:50PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 01:28PM |
SocketServer.cpp(346): Scan found 4 SSIDs SocketServer.cpp(359): found network Jays Wifi BSSID 70:3A:CB:2D:25:76 RSSI -91 SocketServer.cpp(359): found network Jays Wifi BSSID 70:3A:CB:2A:71:1B RSSI -48 SocketServer.cpp(373): No network found scandone
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 03:02PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 04:32PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 05:05PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 05:40PM |
