Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 06:00PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 16, 2020 06:17PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 12:56AM |
DrDitto
Thanks to all.
I will make a deep research.
At the moment I will work changing the new Open source mks tft firmware. Because the one that all mention at the messages did not work. It shows no images for the button.
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 03:40AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 05:25AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 06:25AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 06:27AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 11:28AM |
WiFi reported error: socket number out of range
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 12:37PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 02:51PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 02:53PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 02:58PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 03:08PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 03:20PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 03:24PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 03:25PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 03:33PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 03:35PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 03:53PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 05:40PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 05:59PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 17, 2020 07:04PM |
Attempting connection at \\.\COM8... Testing plaintext communication protocol... READ: ok Connected to machine! SENT: T0 READ: ok SENT: M105 READ: ok T:-273.1 /0.0 T0:-273.1 /0.0 READ: Error: Temperature reading fault on heater 1: sensor open circuit SENT: M122 READ: === Diagnostics === READ: RepRapFirmware for LPC176x based Boards (smoothieboard) version 3.1.0 running on LPC176x at 120Mhz READ: Used output buffers: 2 of 16 (12 max) READ: === RTOS === READ: Static ram: 3624 READ: Dynamic Memory (RTOS Heap 5): 3408 free, 1936 never used READ: Exception stack ram used: 264 READ: Never used ram: 420 READ: Tasks: EMAC(blocked,52) NETWORK(ready,244) IP-task(blocked,88) HEAT(blocked,992) MAIN(running,1460) IDLE(ready,84) READ: Owned mutexes: READ: === Platform === READ: Last reset 00:08:16 ago, cause: [power up] READ: Last software reset details not available READ: Error status: 0 READ: Date/time: 2020-05-17 17:13:00 READ: Slowest loop: 4.99ms; fastest: 0.23ms READ: === Storage === READ: Free file entries: 4 READ: SD card 0 detected READ: SD card longest read time 1.7ms, write time 0.0ms, max retries 0 READ: === Move === READ: Hiccups: 0, FreeDm: 100, MinFreeDm: 100, MaxWait: 0ms READ: Bed compensation in use: none, comp offset 0.000 READ: === DDARing === READ: Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 READ: === Heat === READ: Bed heaters = -1, chamberHeaters = -1 READ: === GCodes === READ: Segments left: 0 READ: Movement lock held by null READ: HTTP is idle in state(s) 0 READ: File is idle in state(s) 0 READ: USB is ready with "M122" in state(s) 0 READ: Aux is idle in state(s) 0 READ: Trigger is idle in state(s) 0 READ: Queue is idle in state(s) 0 READ: LCD is idle in state(s) 0 READ: Daemon is idle in state(s) 0 READ: Autopause is idle in state(s) 0 READ: Code queue is empty. READ: === Network === READ: Slowest loop: 3.55ms; fastest: 0.01ms READ: Responder states: HTTP(0) HTTP(0) READ: HTTP sessions: 1 of 2 READ: Interface state: active, link 10Mbps half duplex READ: Socket States: Listening Listening READ: EthDrv: Dropped packets (no buffer): 35 READ: ok SENT: M105 READ: ok T:-273.1 /0.0 T0:-273.1 /0.0 SENT: M105 READ: ok T:-273.1 /0.0 T0:-273.1 /0.0 Disconnected.
Attempting connection at \\.\COM8... Testing plaintext communication protocol... READ: ok Connected to machine! SENT: T0 READ: ok SENT: M105 READ: ok T:-273.1 /0.0 T0:-273.1 /0.0 SENT: M122 READ: === Diagnostics === READ: RepRapFirmware for LPC176x based Boards (smoothieboard) version 3.1.0 running on LPC176x at 120Mhz READ: Used output buffers: 1 of 16 (12 max) READ: === RTOS === READ: Static ram: 3624 READ: Dynamic Memory (RTOS Heap 5): 4496 free, 1936 never used READ: Exception stack ram used: 264 READ: Never used ram: 420 READ: Tasks: EMAC(blocked,52) NETWORK(ready,244) IP-task(blocked,88) HEAT(blocked,992) MAIN(running,1460) IDLE(ready,84) READ: Owned mutexes: READ: === Platform === READ: Last reset 01:58:02 ago, cause: [power up] READ: Last software reset details not available READ: Error status: 0 READ: Date/time: 2020-05-17 19:02:46 READ: Slowest loop: 5.12ms; fastest: 0.25ms READ: === Storage === READ: Free file entries: 4 READ: SD card 0 detected READ: SD card longest read time 1.8ms, write time 0.0ms, max retries 0 READ: === Move === READ: Hiccups: 0, FreeDm: 100, MinFreeDm: 100, MaxWait: 0ms READ: Bed compensation in use: none, comp offset 0.000 READ: === DDARing === READ: Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 READ: === Heat === READ: Bed heaters = -1, chamberHeaters = -1 READ: === GCodes === READ: Segments left: 0 READ: Movement lock held by null READ: HTTP is idle in state(s) 0 READ: File is idle in state(s) 0 READ: USB is ready with "M122" in state(s) 0 READ: Aux is idle in state(s) 0 READ: Trigger is idle in state(s) 0 READ: Queue is idle in state(s) 0 READ: LCD is idle in state(s) 0 READ: Daemon is idle in state(s) 0 READ: Autopause is idle in state(s) 0 READ: Code queue is empty. READ: === Network === READ: Slowest loop: 1.62ms; fastest: 0.18ms READ: Responder states: HTTP(0) HTTP(0) READ: HTTP sessions: 0 of 2 READ: Interface state: active, link 10Mbps half duplex READ: Socket States: Listening Listening READ: EthDrv: Dropped packets (no buffer): 35 READ: ok SENT: M105 READ: ok T:-273.1 /0.0 T0:-273.1 /0.0 SENT: M105 READ: ok T:-273.1 /0.0 T0:-273.1 /0.0 Disconnected.
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 18, 2020 10:53AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 19, 2020 02:31AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 19, 2020 02:38AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 19, 2020 03:01AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 19, 2020 02:50PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 19, 2020 03:31PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 19, 2020 05:20PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards May 19, 2020 05:21PM |
ChemaFuji
Hi all again!
I have a mystery on my setup, from installing the v3.1.0 the machine is not able to make the height map file. I run the G32 correctly, then try the G29 and it goes to everyone point to measure, but when it finishes, no heightmap.csv file nowhere... Initially, my mind was the file is corrupted or read-only or... so I deleted it, no luck. The strange thing is that after G29, the menu "compensation & calibration" shows the option G29 S2 enabled, as it has the mesh compensation active, so heightmap loaded, but if I push the "load heightmap file" button it fails with the file "/opt/dsf/sd/sys/heightmap.csv" not found.
I'm not sure if the errors become with v3.1.0 as I had not used the G29 since RC8 if my mind is correct so could be something in the middle.
In any case, please try to do G29 and check that the .csv file is written, as I found that fault because it never changed, but I have changed the position of the bed...
Kind regards from Spain.
Chema
