Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 04, 2020 07:18AM |
kostasbmw
hi
just received the lpc board for my skr 1.4 for the rep rap conversion and i m looking for a tutorial of how to......
thanks
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 04, 2020 02:25PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 04, 2020 02:35PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 04, 2020 02:36PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 03:47AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 03:50AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:01AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:05AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:12AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:14AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:21AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:38AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:44AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:46AM |
gloomyandy
Also please note that there is currently no support for the 2130 SPI interface. So you will have no way of setting current etc. via software. You will also probably need to set the number of smart drivers to 0 to stop the firmware trying to talk to them via the UART interface.
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 04:48AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 05:05AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 05:36AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 06:24AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 11:59AM |
jay_s
well you've got something wrong somewhere are your board.txt file is not being loaded.
Can you show the contents of your sd card?
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 05, 2020 12:11PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 06, 2020 09:51AM |
jay_s
@MKSA
Those changes are only in sdavi's build. Gloomyandy doesn't have access to sdavi's changes.
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 07, 2020 03:09AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 19, 2020 10:27AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards July 20, 2020 11:24AM |
Will your settings work with TMC 2209 ?Quote
3DPrintBeginner
Hey guys,
I made a guide on how to install RepRap firmware for Sidewinder X1. You can read it here: RepRap Firmware on Sidewinder X1: SKR 1.3/1.4
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards October 10, 2020 07:16PM |
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.4-LPC-5 on Sat Oct 10 2020 10:37:57 GMT-0700 (Mountain Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-295 Y-295 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-295 ; home X axis G1 H1 Y-295 ; home Y axis G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-295 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-295 ; then move slowly to Y axis endstop G1 H1 Z-205 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards December 18, 2020 08:51AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards December 18, 2020 09:09AM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards January 26, 2021 06:08PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards January 26, 2021 06:16PM |
Re: RepRapFirmware 3.0 port for LPC1768/9 based boards January 26, 2021 06:17PM |
