LPC1768/1769 Port of RepRapFirmware v3.1.x
Posted by gloomyandy
Re: LPC1768/1769 Port of RepRapFirmware v3.1.x
September 02, 2020 03:14AM
gloomyandy
@fenixsz, you will almost certainly get more help if you use the LPC discord server (see the LPC Wiki for details). The M911 command you are trying to use requires that the main board is able to monitor the supply voltage, the BTT SKR boards do not have that feature. When using the BTT UPS it sends a trigger value to the board and it may be possible to configure RRF to use this trigger, but it is not something I've tried nor have I seen any posts from users that have done this and have it working. You should probably ask this question again on the discord server.
Thanks!
Edited 1 time(s). Last edit at 09/02/2020 03:15AM by fenixsz.
October 03, 2020 10:39AM
Any plan for Makerbase MKS Rumba32 180MHZ ?
Ps: i just realised there is another topic for stm32 specific, it seems i can't delete the message too.
Edited 1 time(s). Last edit at 10/03/2020 10:59AM by mechanik.
December 21, 2020 11:24AM
You can ask when you will add version 3.1.1-15 with additional boards (MKS SGen L v2) and pins on 2 stepper motors.
December 21, 2020 11:34AM
@diman77
There won't be a further 3.1.1 release.
3.2 RC1 should be released in a few days time. I would suggest moving to that as its fairly stable
Based in Darlington, North East
