STM32F4/LPC1768/1769 Port of RepRap Firmware V3.2
January 08, 2021 07:03AM
Version 3.2_1 for STM32F4/LPC1768/1769 based boards is now available. Please see:[github.com]
Re: STM32F4/LPC1768/1769 Port of RepRap Firmware V3.2
January 10, 2021 07:20PM
I updated to RRF 3.2 & ever since I'm having an issue with Duet Web Control. I'm running on SKR 1.4T.
I have ESP Wifi Module, flashed with latest 1.25 firmware.
I'm also running Duet Web Control 3.2.
When I'm trying to load the page, it's stuck at "Connecting" although everything in the background seems to be updated. please check the screenshot.
open | download - RRF 3.2.png (338.6 KB)
January 11, 2021 02:58AM
I suggest you connect to the board via USB and send M552 to see whether the WiFi module has connected to the access point.
January 11, 2021 10:28AM
Thanks for the suggestion, but yes it was connected, I can see it on my Router, ping it's IP & even when I try your suggestion, it shows that it's connected to WiFi & provide the same IP address.
January 11, 2021 10:38AM
It looks like a browser issue, when I tried a Private Window (Safari on Mac OS) it works fine! it just won't connect under the normal window.
the "Connecting..." never seem to have the loading bar spinning or filling like normal, it's just stuck there.
Any suggestions?
RRF 3.2-1 on SKR1.4T
ESP-12E Wifi Module (FW ver 1.25-01L-D)
TFT35 V3.0
Duet Web Control 3.2.0
January 12, 2021 02:40AM
We've seen a few issues when using Safari. You could use whatever developer or debug features Safari provides to get a trace of what is going on, perhaps also a Wireshark trace, and post those on the Duet3D forum.
February 02, 2021 08:16AM
Hi all, I'm trying to work out the coupling to a SBM, Raspberry Pi, but I'm running into an issue. I cannot see clearly what goes where when looking at this image:
Is there a higher resolution image available of this? I Googled all over, but it was impossible to find.
Update:
Meanwhile I figured it out, have some nice cables running now, I don't know if it's my laptop's screen, but I found it hard to see the image clearly.
Edited 2 time(s). Last edit at 02/02/2021 04:41PM by Ohmarinus.
http://www.marinusdebeer.nl/
August 04, 2021 05:51AM
I wonder what protocol do you use for SKR - SBC connection? I suppose it's not serial
August 09, 2021 06:54AM
@karabas SPI
Edited 1 time(s). Last edit at 08/09/2021 06:55AM by jay_s.
Based in Darlington, North East
