Recommended host software for Teacup? July 05, 2011 02:03AM |
Re: Recommended host software for Teacup? July 05, 2011 04:12AM |
btns=[ ###Defining custom buttons for pronterface is easy. Here's how. ###Below these instructions, add a line with the following format for each button # ["button name","command",color(RGB )], <--That comma is important, do not forget it ###As an example: (Remove the # to try it out): #["Read temp","M105",(200,100,100)], ###You can use gcodes or any pronsole/pronterface commands ###The first four buttons will end up at the top of the window, visible in mini mode ###The rest of the buttons will be at the bottom of the gcode preview ###ADD BUTTON DEFINITIONS BELOW THIS LINE ["On","M190",(140,200,140)], ["Off","M191",(200,140,140)], ["Nozzle 230","M104 S230",(140,140,140)], ["Bed 110","M140 S110",(140,140,140)], ["Home X","G161 X0",(140,140,200)], ["Home Y","G161 Y0",(140,140,200)], ["Home Z","G162 Z0",(140,140,200)], ["Read Estop","M200",(200,140,200)], ["Read Temp","M105 P0",(200,140,200)], ###ADD BUTTON DEFINITIONS ABOVE THIS LINE ]
Re: Recommended host software for Teacup? July 05, 2011 06:44AM |
