Teacup checksum error August 24, 2011 08:21PM |
Re: Teacup checksum error August 24, 2011 08:54PM |
Re: Teacup checksum error August 24, 2011 10:14PM |
Re: Teacup checksum error August 25, 2011 04:41AM |
0 mm of filament used in this print
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Teacup checksum error August 25, 2011 06:36PM |
Re: Teacup checksum error August 25, 2011 10:47PM |
Re: Teacup checksum error August 26, 2011 01:12PM |
Re: Teacup checksum error August 26, 2011 02:39PM |
Re: Teacup checksum error August 26, 2011 05:59PM |
Re: Teacup checksum error August 26, 2011 06:31PM |
Re: Teacup checksum error August 27, 2011 08:32AM |
It isn't common to have negative numbers in the XYZ moves. This is caused by your STL not being orientated correctly.
Re: Teacup checksum error August 28, 2011 12:11PM |
Re: Teacup checksum error August 29, 2011 05:49AM |
Re: Teacup checksum error August 29, 2011 11:48AM |
Re: Teacup checksum error August 29, 2011 12:12PM |
Re: Teacup checksum error August 29, 2011 06:05PM |
Re: Teacup checksum error August 30, 2011 03:55AM |
Another cause of an axis not going backwards is the endstop for that axis is not working or configured wrong.
Re: Teacup checksum error August 30, 2011 12:16PM |
Re: Teacup checksum error August 30, 2011 01:39PM |
Re: Teacup checksum error August 30, 2011 09:07PM |
Re: Teacup checksum error August 31, 2011 02:02AM |
Re: Teacup checksum error August 31, 2011 09:32AM |
Re: Teacup checksum error August 31, 2011 07:19PM |
Re: Teacup checksum error August 31, 2011 08:54PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Teacup checksum error August 31, 2011 09:11PM |
Re: Teacup checksum error August 31, 2011 09:53PM |
Re: Teacup checksum error September 01, 2011 06:40AM |
I don't know of any machine that runs with negative x and y axis using absolute positioning. This could be causing firmware issues since noone uses it this way.
Re: Teacup checksum error December 18, 2011 05:17AM |
Re: Teacup checksum error December 18, 2011 07:08AM |
Re: Teacup checksum error December 18, 2011 01:46PM |
