Re: Repetier Firmware and Host November 16, 2011 05:29PM |
Re: Repetier Firmware and Host November 16, 2011 06:11PM |
Re: Repetier Firmware and Host December 01, 2011 12:57PM |
Re: Repetier Firmware and Host December 13, 2011 01:29AM |
Re: Repetier Firmware and Host December 13, 2011 02:47AM |
Re: Repetier Firmware and Host December 13, 2011 11:03AM |
Re: Repetier Firmware and Host December 13, 2011 11:30AM |
############################################################## sanguino.name=Sanguino sanguino.upload.protocol=stk500 sanguino.upload.maximum_size=63488 sanguino.upload.speed=38400 sanguino.bootloader.low_fuses=0xFF sanguino.bootloader.high_fuses=0xDC sanguino.bootloader.extended_fuses=0xFD sanguino.bootloader.path=atmega644p sanguino.bootloader.file=ATmegaBOOT_644P.hex sanguino.bootloader.unlock_bits=0x3F sanguino.bootloader.lock_bits=0x0F sanguino.build.mcu=atmega644p sanguino.build.f_cpu=16000000L sanguino.build.core=arduino
Re: Repetier Firmware and Host December 13, 2011 04:11PM |
Re: Repetier Firmware and Host December 16, 2011 05:54AM |
Re: Repetier Firmware and Host December 16, 2011 06:02AM |
Re: Repetier Firmware and Host December 16, 2011 07:54AM |
Re: Repetier Firmware and Host December 16, 2011 08:04AM |
Re: Repetier Firmware and Host December 16, 2011 08:18AM |
Re: Repetier Firmware and Host December 16, 2011 08:48AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Repetier Firmware and Host December 16, 2011 08:56AM |
Re: Repetier Firmware and Host December 16, 2011 08:58AM |
Re: Repetier Firmware and Host December 16, 2011 09:45AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Repetier Firmware and Host December 16, 2011 09:56AM |
Re: Repetier Firmware and Host December 19, 2011 12:07AM |
Re: Repetier Firmware and Host December 19, 2011 03:09AM |
Re: Repetier Firmware and Host December 19, 2011 05:00PM |
Re: Repetier Firmware and Host December 20, 2011 03:47PM |
Re: Repetier Firmware and Host December 20, 2011 05:07PM |
Re: Repetier Firmware and Host December 20, 2011 05:14PM |
Re: Repetier Firmware and Host December 20, 2011 06:04PM |
Re: Repetier Firmware and Host December 23, 2011 12:19AM |
Re: Repetier Firmware and Host December 23, 2011 03:18AM |
#if MOTHERBOARD==6 || MOTHERBOARD==62 #define SIMULATE_PWM #define EXTRUDER_TIMER_VECTOR TIMER2_COMPA_vect #define EXTRUDER_OCR OCR2A #define EXTRUDER_TCCR TCCR2A #define EXTRUDER_TIMSK TIMSK2 #define EXTRUDER_OCIE OCIE2Ainto
#if MOTHERBOARD==6 || MOTHERBOARD==62 || MOTHERBOARD==7 #if MOTHERBOARD!=7 #define SIMULATE_PWM #endif #define EXTRUDER_TIMER_VECTOR TIMER2_COMPA_vect #define EXTRUDER_OCR OCR2A #define EXTRUDER_TCCR TCCR2A #define EXTRUDER_TIMSK TIMSK2 #define EXTRUDER_OCIE OCIE2AIf you are using 0.40 the SIMULATE_PWM define is not present
Re: Repetier Firmware and Host December 23, 2011 07:43AM |
Re: Repetier Firmware and Host December 23, 2011 06:04PM |
// #define HAVE_HEATED_BED false #define HAVE_HEATED_BED true // #define HEATED_BED_SENSOR_TYPE 0 #define HEATED_BED_SENSOR_TYPE 1 // #define NUM_ANALOG_SENSORS 1 #define NUM_ANALOG_SENSORS 2 // #define ANALOG_INPUT_CHANNELS {TEMP_0_PIN} #define ANALOG_INPUT_CHANNELS {TEMP_0_PIN,TEMP_1_PIN}
Re: Repetier Firmware and Host December 23, 2011 06:15PM |
