Re: Repetier Firmware and Host February 05, 2012 09:49AM |
Re: Repetier Firmware and Host February 11, 2012 01:46PM |
System.ArgumentOutOfRangeException: ArgRange_Array Parameter name: count at System.Text.ASCIIEncoding.GetCharCount (System.Byte[] bytes, Int32 index, Int32 count) [0x00000] in :0 at System.Text.Encoding.GetChars (System.Byte[] bytes, Int32 index, Int32 count) [0x00000] in :0 at System.IO.Ports.SerialPort.ReadExisting () [0x00000] in :0 at (wrapper remoting-invoke-with-check) System.IO.Ports.SerialPort:ReadExisting () at RepetierHost.model.PrinterConnection.ReadThread () [0x00000] in :0So it is the host, Anyway the firmware continue to stabilize the temperature, and the FTDI works fine after that with the arduino frameworks...
Re: Repetier Firmware and Host February 12, 2012 03:28AM |
Re: Repetier Firmware and Host February 12, 2012 05:11AM |
Re: Repetier Firmware and Host February 12, 2012 05:27AM |
Re: Repetier Firmware and Host February 12, 2012 08:05AM |
Re: Repetier Firmware and Host February 12, 2012 06:20PM |
18:22:23.726 : Resend: N496 G1 X69.65 Y103.65 F6000 *95 18:22:23.728 : Resend: N497 G1 X65.35 Y103.65 E7.16746 F1800 *22 18:22:23.729 : Resend: N498 G1 X65.35 Y66.35 E7.69605 *79 18:22:23.735 : N499 G1 X104.65 Y66.35 E8.25299 *123 18:22:23.744 : N500 G1 X104.65 Y70.65 E8.31392 *119 18:22:23.767 : N501 G1 X69.65 Y70.65 E8.80992 *76 18:22:23.791 : N502 G1 X69.65 Y103.545 E9.27609 *76 18:22:23.943 : Error:Binary cmd wrong checksum. 18:22:23.943 : Resend:497 18:22:23.944 : Resend: N497 G1 X65.35 Y103.65 E7.16746 F1800 *22 18:22:23.947 : Resend: N498 G1 X65.35 Y66.35 E7.69605 *79 18:22:23.949 : Resend: N499 G1 X104.65 Y66.35 E8.25299 *123 18:22:23.950 : Resend: N500 G1 X104.65 Y70.65 E8.31392 *119 18:22:23.952 : Resend: N501 G1 X69.65 Y70.65 E8.80992 *76 18:22:23.954 : Resend: N502 G1 X69.65 Y103.545 E9.27609 *76 18:22:23.958 : N503 G1 E6.27609 F1500 *43 18:22:23.998 : N504 G1 Z0.95 F6000 *1 18:22:23.998 : N505 G92 E0 *103 18:22:24.051 : N506 G1 X67.502 Y101.878 *59 18:22:24.199 : N507 G1 Z0.45 *111 18:22:24.200 : N508 G1 E3 F1500 *49 18:22:24.255 : Error:Binary cmd wrong checksum. 18:22:24.255 : Resend:501 18:22:24.256 : Resend: N501 G1 X69.65 Y70.65 E8.80992 *76 18:22:24.258 : Resend: N502 G1 X69.65 Y103.545 E9.27609 *76 18:22:24.260 : Resend: N503 G1 E6.27609 F1500 *43 18:22:24.261 : Resend: N504 G1 Z0.95 F6000 *1 18:22:24.263 : Resend: N505 G92 E0 *103 18:22:24.264 : Resend: N506 G1 X67.502 Y101.878 *59 18:22:24.265 : Resend: N507 G1 Z0.45 *111 18:22:24.266 : Resend: N508 G1 E3 F1500 *49 18:22:25.409 : N509 G1 X67.502 Y68.122 E3.48168 F1800 *40 18:22:26.234 : N510 M105 *3 18:22:26.624 : N511 G1 X68.188 Y68.122 E3.49147 *75 18:22:26.676 : N512 G1 X68.188 Y68.878 E3.50226 *66 18:22:28.937 : Error:Binary cmd wrong checksum. 18:22:28.938 : Resend:506 18:22:28.938 : Resend: N506 G1 X67.502 Y101.878 *59 18:22:28.939 : Resend: N507 G1 Z0.45 *111 18:22:28.942 : Resend: N508 G1 E3 F1500 *49 18:22:28.943 : Resend: N509 G1 X67.502 Y68.122 E3.48168 F1800 *40 18:22:28.944 : Resend: N510 M105 *3 18:22:28.946 : Resend: N511 G1 X68.188 Y68.122 E3.49147 *75 18:22:28.947 : Resend: N512 G1 X68.188 Y68.878 E3.50226 *66 18:22:28.951 : Error: expected line 506 got 507 18:22:28.951 : Resend:506 18:22:28.952 : Resend: N506 G1 X67.502 Y101.878 *59 18:22:28.954 : Resend: N507 G1 Z0.45 *111 18:22:28.955 : Resend: N508 G1 E3 F1500 *49 18:22:28.956 : Resend: N509 G1 X67.502 Y68.122 E3.48168 F1800 *40 18:22:28.958 : Resend: N510 M105 *3 18:22:28.960 : Resend: N511 G1 X68.188 Y68.122 E3.49147 *75 18:22:28.961 : Resend: N512 G1 X68.188 Y68.878 E3.50226 *66 18:22:28.964 : N513 G1 X68.874 Y68.878 E3.51206 *74 18:22:28.968 : N514 G1 X68.874 Y68.122 E3.52285 *67 18:22:29.059 : N515 G1 X69.56 Y68.122 E3.53264 *117 18:22:29.235 : N516 M105 *5 18:22:31.519 : N517 G1 X69.56 Y68.878 E3.54344 *117 18:22:31.524 : Error:Binary cmd wrong checksum. 18:22:31.528 : Resend:512 18:22:31.529 : Resend: N512 G1 X68.188 Y68.878 E3.50226 *66 18:22:31.531 : Resend: N513 G1 X68.874 Y68.878 E3.51206 *74 18:22:31.532 : Resend: N514 G1 X68.874 Y68.122 E3.52285 *67 18:22:31.534 : Resend: N515 G1 X69.56 Y68.122 E3.53264 *117 18:22:31.536 : Resend: N516 M105 *5
Re: Repetier Firmware and Host February 13, 2012 03:13AM |
Re: Repetier Firmware and Host February 13, 2012 07:53AM |
Re: Repetier Firmware and Host February 17, 2012 06:23AM |
Re: Repetier Firmware and Host February 17, 2012 10:56AM |
Re: Repetier Firmware and Host February 17, 2012 11:09AM |
Re: Repetier Firmware and Host February 17, 2012 11:40AM |
Re: Repetier Firmware and Host February 17, 2012 11:42AM |
Re: Repetier Firmware and Host February 17, 2012 01:29PM |
Re: Repetier Firmware and Host February 17, 2012 01:43PM |
Re: Repetier Firmware and Host February 19, 2012 08:18PM |
Re: Repetier Firmware and Host February 20, 2012 03:14AM |
#define EXT0_TEMPSENSOR_PIN 0
Put all the pin numbers for the analog sensors (temp. sensor for extruder and heated bed) in here. In the configs of the sensor, use the index in this array. For the typical combination of one extruder with heated bed, write: #define ANALOG_INPUT_CHANNELS {TEMP_0_PIN,TEMP_1_PIN} */ #if HAVE_HEATED_BED==true #define ANALOG_INPUT_CHANNELS {TEMP_0_PIN,TEMP_1_PIN} #else #define ANALOG_INPUT_CHANNELS {TEMP_0_PIN} #endif
Re: Repetier Firmware and Host February 20, 2012 04:53PM |
#define EXT0_TEMPSENSOR_PIN 0I had put a 1 instead of the 0, now all is all right, and work really well, just a question what configuration I have to change to have some more smooth movements ? I found that it's a little violent, my prusa dance like an epileptic when doing some small moves, I have reduce the jerk, and the feedrate, but it's not that smooth, is there a way ?
Re: Repetier Firmware and Host February 21, 2012 02:37AM |
Re: Repetier Firmware and Host February 24, 2012 06:17PM |
Re: Repetier Firmware and Host February 25, 2012 03:20AM |
Re: Repetier Firmware and Host February 25, 2012 06:13AM |
Re: Repetier Firmware and Host February 25, 2012 06:33AM |
Re: Repetier Firmware and Host February 25, 2012 08:43AM |
Re: Repetier Firmware and Host February 27, 2012 10:15AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Repetier Firmware and Host April 01, 2012 10:22AM |
Re: Repetier Firmware and Host April 01, 2012 10:36AM |
Re: Repetier Firmware and Host April 01, 2012 10:47AM |
Re: Repetier Firmware and Host April 01, 2012 11:10AM |
