End stops not working? October 24, 2011 06:19PM |
Re: End stops not working? October 24, 2011 07:12PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: End stops not working? October 24, 2011 07:45PM |
Re: End stops not working? October 24, 2011 07:51PM |
Re: End stops not working? October 24, 2011 08:00PM |
Re: End stops not working? October 25, 2011 06:47AM |
If I change it to
#define ENDSTOPPULLUPS
const bool ENDSTOPS_INVERTING = false
They jump around and act really weird. They only move in one direction.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: End stops not working? October 25, 2011 08:35AM |
Re: End stops not working? October 26, 2011 05:26AM |
How would you suggest fixing noise?
I thought that is why the documentation has pull up resistors
Can I put a cap between the two pins on the switch to get rid of the noise?
As a side note, can I just turn off endstops completely in the firmware?
Re: End stops not working? October 26, 2011 06:14AM |
Admin Registered: 17 years ago Posts: 7,879 |
