The openscad source files are in the github project: [
github.com]
Be careful which version you require - the master branch is version 2 - version 1 is in a branch called oldmaster
Otherwise, there is a plugin for Google Sketchup which allows you to import STL files (http://sketchuptips.blogspot.com/2010/03/sketchup-stl-importer-redo.html) this can then be exported as STL with the following plugin (http://www.guitar-list.com/download-software/convert-sketchup-skp-files-dxf-or-stl) (Note: when importing STL files you have to explicitly select "millimeters" from the options page found on the file import dialog, otherwise the model will be the wrong scale).
Hope it helps.
garyhodgson.com/reprap |
reprap.development-tracker.info |
thingtracker.net
