Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 11, 2012 02:42PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 12, 2012 05:05PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 13, 2012 06:20AM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 13, 2012 11:58AM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 13, 2012 12:40PM |
Admin Registered: 19 years ago Posts: 7,883 |
my happy reprap June 13, 2012 03:39PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 13, 2012 04:37PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 13, 2012 04:54PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 13, 2012 04:58PM |
Re: my happy reprap June 13, 2012 05:58PM |
One coupling was perfect and with the other coupling none of the four nuts did fit, no way.
Re: my happy reprap June 14, 2012 01:26AM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 14, 2012 01:39AM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 14, 2012 02:26AM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 14, 2012 06:53AM |
PCB Bed has two sides, one with the traces (bottom side) and one with silkscreen (top).
Printing on top side is safer, works great.
Printing on bottom is more effective and heats up quicker. (Though the LED, resistor and wire connections are liable to collision with the print head. Also the tracks could be damaged if the print head collides. Make sure your z-bed-springs are not too strong to prevent damage during a collision).
roland
found the trick to put a 1k ohm resistor between the green cable and a black one to get the power supply working :-))
the red led on the singubumboard lights up:-)))
did plug in the usb connector and with internet-driver-lookup (windows xp), a usb-serial adapter was installed.
downloaded the reprap-host-software.
starting the reprap.bat , the extruder-stepper makes some noise.
Now i would like to enter some coordinates in the xyz-tab of that software and see my beloved reprap moving.
but nothing happens :'(
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 14, 2012 07:34AM |
But the neodym-magnets inside the stepper motors must be kept below 60°C
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 14, 2012 08:30AM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 14, 2012 11:37AM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 14, 2012 02:07PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 14, 2012 02:48PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 15, 2012 12:01PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 15, 2012 01:51PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 15, 2012 04:37PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 15, 2012 07:07PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 16, 2012 12:24PM |
This is a Sanguinololu firmware compatible board, though does have a couple of extra features the Sanguinololu does not
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 16, 2012 02:58PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 16, 2012 06:08PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 16, 2012 06:43PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 16, 2012 06:58PM |
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 16, 2012 07:04PM |
Anybody know what the function of this button?
Re: thereprapkitstore.com Prusa Mendel construction Notes/Discussions June 17, 2012 11:50AM |
