filament proper diameter.
Posted by Gaou
October 30, 2015 04:37PM
Guys hello again. I am in the procces of creating my own filament and i was wondering what sizes are "the no go" and i should avoid? also the problem with bigger diameters is the clocked extruder (i think at least ) what is it the problem with the smaller one? i mean if i l ll insert 1.5mm inside the tube and adjust the slic3r on the right filament width what would be the problem ? Thanks guys be well.
Re: filament proper diameter.
October 31, 2015 07:57AM
One of the problems if you get away from the 1.74 and 3mm sizes is that you nedd custom made parts from the extruder down to the actual nozzle tip.
October 31, 2015 03:44PM
Downunder35m
ok other than this . I mean if i produse 1.85mm filament would it be able to be extruded from my mendel or i ll have problems printing with that. ?
November 02, 2015 05:32AM
1.75mm extruder's parts uses 2mm inside diameters.
0.15 gap is not enough for a fluent drive.
For parts, a tight fit is a 0.2mm gap.
Appreciate that friction and heating elements are expanding factors for the filament.
That's why the standard for 2mm holes are 1.75mm.
IMHO a 1.85mm can jam easily.
++JM
November 05, 2015 03:17AM
thanks man . i ll try to get it at 1.75
