Z calibration
Posted by pictux
Z calibration
August 15, 2012 05:55PM
Hi all,
my env:
- RAMPS 1.2 with sprinter fw
- pronterface
- Slic3r 0.9.1 / Cura
i'm trying to print this one:
[www.thingiverse.com]
but results is good only for the first 20 layer, as you can see here:
[lh6.googleusercontent.com]
Any hint/suggestion?
Regards
M
Edited 1 time(s). Last edit at 08/16/2012 06:04PM by pictux.
Re: Z calibration
August 15, 2012 06:04PM
More info please - like slicing settings
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
Re: Z calibration
August 15, 2012 06:08PM
Hi akhlut,
here attached my Cura settings.
Regards
M
open | download - cura_config_2.ini (2 KB)
Re: Z calibration
August 16, 2012 03:22AM
Looks like you're printing too fast or not using a fan -- the layers don't have time to cool before the next one is laid down, resulting in a big melted mess.
Re: Z calibration
August 16, 2012 06:01PM
thanks for the hints.
So, new setup:
- added a fan
- used a lower temp (185/190 °C instead of 200°C)
- used a lower speed (40 mm/s instead of 50 mm/s)
You can see the result here:
[lh3.googleusercontent.com]
it not seems still ok.
I've tried also to print again, from here:
- the .5mm thin wall:
[lh5.googleusercontent.com]
- the 20mm box
Any hints?
Regards
M
Edited 1 time(s). Last edit at 08/16/2012 06:03PM by pictux.
Re: Z calibration
August 16, 2012 07:04PM
Looks like your z-axis is losing steps.
You might try lowering the max speed of the z-axis.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
Re: Z calibration
August 16, 2012 08:05PM
thanks for the reply.
Test setup:
- used a lower Max Z speed (2.0 instead of 3.0)
Results
[lh4.googleusercontent.com]
- the 20mm box
it seems much worse than before.
Re: Z calibration
August 17, 2012 03:27AM
Oh God... eye popping smiley the 20mm box looks even WORSE. confused smiley
Bob Morrison
Re: Z calibration
August 21, 2012 12:37AM
Could the issue be related to the 20mm box' file?
Because the 5mm thin wall print looks pretty good.
Re: Z calibration
August 21, 2012 06:02AM
Ahem. There's the G4 command, which pauses execution. Not very popular in the RepRap community, but inserted after each layer, it should solve cooling problems of small parts. With or without fan. A G4 P20000 pauses for 20 seconds.
Re: Z calibration
August 21, 2012 08:01AM
As an aside thought, if you are pausing for more than a couple of seconds, is it worth considering re-homing the X/Y axis, especially if you are concerned about skipping steps?
Re: Z calibration
August 21, 2012 12:17PM
No, the motors would still be powered and will hold position.
Re: Z calibration
August 30, 2012 07:56PM
Thanks all,
here i am.
So, i've changed the firmware, now i'm using the Marlin.
After this update, Slic3r seems to work very well (Cura instead seems to work very bad with Marlin fw....)
So, new setup:
- used a lower temp (173 °C - i'm using PLA)
- used a lower speed (30 mm/s)
https://lh5.googleusercontent.com/-Aqd9bf6asKQ/UD8eSlsDlaI/AAAAAAAAERk/vVpEhZryqFg/s800/DSCF0296.JPG
https://lh4.googleusercontent.com/-UXF0qH0d61c/UD8ehkSuj2I/AAAAAAAAESE/UWjYeP_AEFs/s800/DSCF0301.JPG
What do you think?
Now i'd like to fix other issues related to print quality...
Maybe it's better if i open a new thread!
Regards
M
Re: Z calibration
August 31, 2012 10:20AM
Do you have a photo of your machine? And can you make a picture of your z axis? Is the z threaded rod fixed at th butom or not?
I think i know what the problem Is.
[url=http:// www.facebook.com/Charlied3DCreations]www.facebook.com/Charlied3DCreations[/url]
Charlie
