Why not glue the glass directly to the pcb heater?
Posted by Wired1
September 07, 2012 10:27PM
Well, why not? I guess it works for me as I am using PLA with a bed temperature of 60 degrees C, not sure they make adhesives that can take the ABS bed temperatures.
Reason I'm thinking of this is I haven't removed my glass for so long now it seems pointless to have to use those annoying bulldog clips - they only get in the way of larger prints. The printer I am currently building will have a print area of 220 - 230mm square without them.
It is easy enough to clean the glass with it in place with a razor blade so why make it removeable at all?
_________________________________________________________________________________________
Richmond, New Zealand
Thingiverse ~ YouTube
Re: Why not glue the glass directly to the pcb heater?
September 07, 2012 10:33PM
The board flexes when it gets hot, that puts stress on the glass, the clips allow the glass and the board to move relative to each other.
You might get away with It, but there is a chance those forces could break the glass if it were glued to the heated bed.
September 08, 2012 01:55AM
Thanks, that makes sense - bugger.
September 08, 2012 05:12AM
I use diluted PVA to prevent curling and I frequntly remove glass to aid part removal from the bed. I've also proken my glass a couple of time because my Z axis end stop switch has moved without me noticing.I also wash my glass frequently in the kitchen sink to remove PVA glue.
Glueing the glas to the bed would not be a good idea.
Using ABSPrusa Mendel Zaphod with Pronterface and slic3r 1.3.0. Printing well with 3mm PLA and ABS through 2 x J Head Mk IV b and Wade Geared Exruders. Controlled using RAMPS1.4 board running Marlin_v1.1.9
September 08, 2012 05:29AM
Are you using PVA glue instead of a heated bed or as well as it? I find the hot bed holds it fast then releases it cleanly when it cools.
