Not Sure on What to Calebrate (NOOcool smiley
September 13, 2012 07:11AM
So I got a RepRap, Assembled it, and am trying to calibrate it, but can't seem to fathom what I should be looking at.
I have leveled the bed.
and tried layer heights, but I am astill get the same problem.
attached is a picture, if anybody can help.
Thanks
open | download - 20120913_074809.jpg (192.7 KB)
Re: Not Sure on What to Calebrate (NOOcool smiley
September 13, 2012 10:43AM
Do you have a pair of digital calipers?
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
September 13, 2012 03:14PM
Your fillament looks too blob-y and fluid. maybe something is too hot, like your hot end or bed. or maybe you have your firmware set to extrude too much per step.
September 14, 2012 04:38AM
I don't have digital calipers, but what would I be doing with them ?
Thanks
September 14, 2012 04:39AM
Buback : Thanks, I will try changing the temperature,
although I have set the values to 230 and 110, but maybe the sensor is not touching the piece of glass.
Thanks
September 14, 2012 10:22AM
The hollow thin-walled object is more of an advanced test object, so you can try printing an easier test block. I like the 40x40x5 solid block. It's probably the easiest to start with. Once you get the first few solid layers done, you can already see whether the extrusion is too much or too little. (Or whether there are some other problems.)
open | download - 40x40x5.stl (2.7 KB)
September 14, 2012 03:43PM
Well, you need a pair of digital calipers to accurately measure your test objects. But more fundamentally you need them to tell if an x/y/z move was the proper distance.
This way if you tell the x-axis to move 50mm you can measure that it actually went 50mm.
- akhlut
