Exchange filament?
November 07, 2012 07:16AM
What is the best way/procedure to exchange the filament in a J-head hotend?
I want to switch to a different color but I can not get it out...
Prusa with cast PU parts, RAMPS 1.3, Wades extruder, J-Head hot end
VDX
Re: Exchange filament?
November 07, 2012 07:20AM
... start the heater and pull it out, when the outer surface gets soft ...
Viktor
November 07, 2012 10:25AM
I tried to pull it up with the nozzle warm and I got it up about 2cm. After that it was stuck really hard, I did not dare pull harder. Is that normal?
Is it possible to cut the filament and push it down with the new color?
VDX
November 07, 2012 10:39AM
... you can flush the filament with the new colour, but this can need some ten centimeters of filament, until all old is gone ... and don't mix PLA with ABS or you'll probably clogg your nozzle.
Viktor
November 07, 2012 01:48PM
Well, I think that the mixed colors might be interesting anyway, I will try that method, thank you!
November 07, 2012 02:53PM
I usually the technique that viktor mentions above in the initial reply, but before I pull UP on the filament, I push DOWN about a centimeter to make sure that a good bit of the filament is softened. After pushing down, I can generally pull up pretty easily. Sometimes I have to repeat the technique.
