Resistance between power connector screws
Posted by pjotrx
November 17, 2012 08:08AM
Hello,
I just finished assembling my RepRapPro Mendel and started checking resistances at several points, following the assembly instructions. For the resistance between the screws of the power connector on the board, the instructions say this should level out to "infinity", which obviously depends on your perspective / multimeter settings. I'm reading 136.2 Ohms on my machine. Is this a plausible value for a correctly assembled machine, or should I go and find out what I did wrong? Thanks in advance for your replies.
Re: Resistance between power connector screws
November 18, 2012 08:20AM
The cause for the low resistance turned out to be the cooling fan which is also attached to the power connector...
