Z endstop adjustment
Posted by pdhammond
March 24, 2013 06:41PM
I'm having trouble getting the mechanical Z endstop adjusted properly and then staying there on a Prusa. Am I missing something? It seems that the Z endstop positioning is really important to getting a decent print, but the adjustment is very crude. Is there any good reason not to have the microswitch pushing onto a fine adjustment screw on the X carriage?
Thanks,
Pete.
Edited 1 time(s). Last edit at 03/24/2013 06:46PM by pdhammond.
Re: Z endstop adjustment
March 24, 2013 10:18PM
Nope, lots of modifications like this on thingiverse. Makes it much easier to tweak the z location.
March 25, 2013 03:38AM
March 25, 2013 10:17AM
Looks good, if I could get my Z range adjusted I'd be able to print one smiling smiley
March 25, 2013 10:18AM
Thanks, my Google-fu let me down.
March 25, 2013 01:19PM
Most G code generation software allows you to add start code to your G code file. A good method is to set the end stop somewhere near, then modify the zero position in software (you do a slight move in Z and reset the datum). It saves constantly having to move the mechanical end stop.
Edited 1 time(s). Last edit at 03/26/2013 09:01AM by martinprice2004.
Helium Frog Website
March 26, 2013 02:50AM
Also read this blog post by nophead:
[hydraraptor.blogspot.com.au]
That gives arguments for another option.
RepRob
March 30, 2013 06:44AM
Has anyone tried to mount Z-Endstop on the Extruder Head - sensoring when z-is making the extruder touching the bed?
I'm just thinking about this idea to get it automatically adjusted to my bed anytime I go to z-Home.
(a clean bed would be essential requirement)
Would a mechanical micro sitch be accurate enough? Or are other sensoring methods more suitable for that?
I think popular opto-endstops would not work, because for using them a defined x-y would be necessary to hit the opto-counterpart (aluminium plate ...)
So maybe a reflected light barrier or mechanical switch would be better.
February 08, 2014 03:03AM
martinprice2004
Could this be done with proterface to remove the need to re-slice when the bed gets bumped?
I'm off to work out how to do this. If someone can tell me that would be appreciated.
Thanks.
