pronterface
Posted by kelly44408
pronterface
March 28, 2013 11:31PM
newb here
buildt printer installed drivers and downloaded sprinter.
pronterface connects and comes back with giberish
not words...
Re: pronterface
March 29, 2013 12:52AM
Sounds like a baud rate issue. Make sure you have pronterface set to the right speed.
JT
Re: pronterface
March 29, 2013 08:16AM
if not sure see attachment
open | download - baud seetting.png (332.9 KB)
Re: pronterface
March 29, 2013 06:29PM
baud rate matches it is communicating but the dialogue box to the right in the image is in symbols and characters.
JT
Re: pronterface
March 29, 2013 07:53PM
ok,
try selecting 9600 baud and connect
if you dont get somthing resembling english try the next baud rate in the drop down,
its quicker to try them all than look at the sprinter code in the arduino ide (config tab)?
give it a go you cant screw anything up - one of the will work.
the characters instead of text is because the baud is still not correct
Im using sprinter so its strange your setting isnt the same
J.
Re: pronterface
March 30, 2013 10:26AM
thanks
it was the 250000 baud rate to fix
