Here is my Prusa i3 ! July 05, 2013 06:38PM |
Re: Here is my Prusa i3 ! July 05, 2013 06:51PM |
Re: Here is my Prusa i3 ! July 06, 2013 03:52AM |
doesn't seem to be affecting the prints, I may give that a go.|
Re: Here is my Prusa i3 ! July 06, 2013 04:37AM |
Re: Here is my Prusa i3 ! July 06, 2013 05:10AM |
Re: Here is my Prusa i3 ! July 11, 2013 02:02AM |
Re: Here is my Prusa i3 ! July 16, 2013 08:08AM |
Re: Here is my Prusa i3 ! July 17, 2013 03:15PM |
Re: Here is my Prusa i3 ! August 13, 2013 07:27PM |
Re: Here is my Prusa i3 ! August 14, 2013 07:06AM |
Re: Here is my Prusa i3 ! August 16, 2013 02:09PM |
Now with dual extrusion! September 21, 2013 12:29PM |
Re: Here is my Prusa i3 ! September 21, 2013 09:12PM |
Re: Here is my Prusa i3 ! September 23, 2013 06:37PM |
Re: Here is my Prusa i3 ! September 27, 2013 04:10PM |
Changed the idler bearings to 624Z bearings. It looks nicer and works better than with the 608Z and plastic guides.
Re: Here is my Prusa i3 ! September 29, 2013 12:10AM |
Re: Here is my Prusa i3 ! September 29, 2013 03:40AM |
Re: Here is my Prusa i3 ! September 29, 2013 03:53AM |
Re: Here is my Prusa i3 ! September 29, 2013 07:05AM |
Re: Here is my Prusa i3 ! September 29, 2013 10:22AM |
I had to re-print the idler holders for X and Y. The X one is the black plastic part which slides into the x-end. I think that the x-end for 624 bearings is also a bit different if you get it for 624 idler bearings but it worked with my original 608 x-end so I did not re-print it.
2. On your direct drive extruder.
> I am in the US and I cannot seem to find a 5x10x5
> bearing (or even a 5x11x5) anywhere online. 5x10x4
Yes, actually, it was a mistake in my description, I am using a 5x10x4.
Well, it is not only to be able to have a second piece of glass. It is actually quite convenient to be able to easily remove the built plate to remove the print, clean the plate, put some kapton tape on it, etc. I think that I would go with the alu mk3 bed since it give you all the options but if you are trying to minimize cost, the mk2 + glass is a well proven solution.
johna
We will post our BOM and manual after the class in case you are looking for a current list.
Re: Here is my Prusa i3 ! September 29, 2013 12:03PM |
Re: Here is my Prusa i3 ! September 29, 2013 05:41PM |
Re: Here is my Prusa i3 ! September 29, 2013 06:49PM |
Re: Here is my Prusa i3 ! September 29, 2013 06:55PM |
Re: Here is my Prusa i3 ! September 30, 2013 02:18PM |
Re: Here is my Prusa i3 ! September 30, 2013 03:26PM |
Re: Here is my Prusa i3 ! September 30, 2013 03:43PM |
Re: Here is my Prusa i3 ! September 30, 2013 03:56PM |
Re: Here is my Prusa i3 ! September 30, 2013 05:53PM |
Re: Here is my Prusa i3 ! September 30, 2013 06:03PM |
