Stepping Inconsistencies [Sanguinololu] [Prusa] August 20, 2013 10:59AM |
Re: Stepping Inconsistencies [Sanguinololu] [Prusa] August 20, 2013 11:55AM |
Re: Stepping Inconsistencies [Sanguinololu] [Prusa] August 20, 2013 12:42PM |
* Sanguinololu pin assignment
#if MOTHERBOARD == 64
#define STB
#endif
#if MOTHERBOARD == 63 || MOTHERBOARD == 66
#define MELZI
#endif
#if MOTHERBOARD == 65
#define AZTEEG_X1
#endif
#if MOTHERBOARD == 62 || MOTHERBOARD == 63 || MOTHERBOARD == 64 || MOTHERBOARD == 65 || MOTHERBOARD == 66
#undef MOTHERBOARD
#define MOTHERBOARD 6
#define SANGUINOLOLU_V_1_2
#endif
#define KNOWN_BOARD 1
#ifndef __AVR_ATmega644P__
#ifndef __AVR_ATmega1284P__
#error Oops! Make sure you have 'Sanguino' selected from the 'Tools -> Boards' menu.
#endif
#endif
#define X_STEP_PIN 15
#define X_DIR_PIN 21
#define X_STOP_PIN 18
#define Y_STEP_PIN 22
#define Y_DIR_PIN 23
#define Y_STOP_PIN 19
#define Z_STEP_PIN 3
#define Z_DIR_PIN 2
#define Z_STOP_PIN 20
#define E0_STEP_PIN 1
#define E0_DIR_PIN 0
#define LED_PIN -1
#define FAN_PIN -1
#if FAN_PIN == 12 || FAN_PIN ==13
#define FAN_SOFT_PWM
#endif
#ifdef MELZI
#define LED_PIN 27 /* On some broken versions of the Sanguino libraries the pin definitions are wrong, which then needs LED_PIN as pin 28. But you better upgrade your Sanguino libraries! See #368. */
#define FAN_PIN 4
#endif
#ifdef STB
#define FAN_PIN 4
// Uncomment this if you have the first generation (V1.10) of STBs board
#define LCD_PIN_BL 17 // LCD backlight LED
#endif
#ifdef AZTEEG_X1
#define FAN_PIN 4
#endif
#define PS_ON_PIN -1
#define KILL_PIN -1
#define HEATER_0_PIN 13 // (extruder)
#define HEATER_1_PIN -1
#define HEATER_2_PIN -1
#ifdef SANGUINOLOLU_V_1_2
#define HEATER_BED_PIN 12 // (bed)
#define X_ENABLE_PIN 14
#define Y_ENABLE_PIN 14
#define Z_ENABLE_PIN 26
#define E0_ENABLE_PIN 14
#else
#define HEATER_BED_PIN 14 // (bed)
#define X_ENABLE_PIN -1
#define Y_ENABLE_PIN -1
#define Z_ENABLE_PIN -1
#define E0_ENABLE_PIN -1
#endif
#define TEMP_0_PIN 7 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! (pin 33 extruder)
#define TEMP_1_PIN -1
#define TEMP_2_PIN -1
#define TEMP_BED_PIN 6 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! (pin 34 bed)
#define SDPOWER -1
#define SDSS 31
/* On some broken versions of the Sanguino libraries the pin definitions are wrong, which then needs SDSS as pin 24. But you better upgrade your Sanguino libraries! See #368. */
//#define SDSS 24
#ifdef ULTRA_LCD
#ifdef NEWPANEL
//we have no buzzer installed
#define BEEPER -1
//LCD Pins
#ifdef DOGLCD
// Pins for DOGM SPI LCD Support
#define DOGLCD_A0 30
#define DOGLCD_CS 29
// GLCD features
#define LCD_CONTRAST 1
// Uncomment screen orientation
// #define LCD_SCREEN_ROT_0
// #define LCD_SCREEN_ROT_90
#define LCD_SCREEN_ROT_180
// #define LCD_SCREEN_ROT_270
#else // standard Hitachi LCD controller
#define LCD_PINS_RS 4
#define LCD_PINS_ENABLE 17
#define LCD_PINS_D4 30
#define LCD_PINS_D5 29
#define LCD_PINS_D6 28
#define LCD_PINS_D7 27
#endif
//The encoder and click button
#define BTN_EN1 11
#define BTN_EN2 10
#ifdef LCD_I2C_PANELOLU2
#ifdef MELZI
#define BTN_ENC 29 //the click switch
#define SDSS 30 //to use the SD card reader on the Panelolu2 rather than the melzi board
#else
#define BTN_ENC 30 //the click switch
#endif
#else
#define BTN_ENC 16 //the click switch
#endif //Panelolu2
//not connected to a pin
#define SDCARDDETECT -1
#endif //Newpanel
#endif //Ultipanel
#ifdef MAKRPANEL
#define BEEPER 29
#define DOGLCD_CS 17
#define LCD_PIN_BL 28 // backlight LED on PA3
// GLCD features
// #define LCD_SCREEN_ROT_180
#define BTN_EN1 11
#define BTN_EN2 10
#endif //Makrpanel
#endif
Re: Stepping Inconsistencies [Sanguinololu] [Prusa] August 20, 2013 02:50PM |
Re: Stepping Inconsistencies [Sanguinololu] [Prusa] August 20, 2013 11:17PM |
Re: Stepping Inconsistencies [Sanguinololu] [Prusa] August 21, 2013 12:17AM |
