Re: Bed Auto Leveling.. check this out October 30, 2013 04:55AM |
Re: Bed Auto Leveling.. check this out October 30, 2013 05:04AM |
Re: Bed Auto Leveling.. check this out October 30, 2013 01:06PM |
Re: Bed Auto Leveling.. check this out October 30, 2013 01:07PM |
Re: Bed Auto Leveling.. check this out October 30, 2013 01:48PM |
Re: Bed Auto Leveling.. check this out October 31, 2013 05:49PM |
Re: Bed Auto Leveling.. check this out November 03, 2013 04:53PM |
Re: Bed Auto Leveling.. check this out November 03, 2013 05:14PM |
Re: Bed Auto Leveling.. check this out November 03, 2013 09:14PM |
Re: Bed Auto Leveling.. check this out November 04, 2013 03:01AM |
Re: Bed Auto Leveling.. check this out November 04, 2013 04:44AM |
Re: Bed Auto Leveling.. check this out November 04, 2013 05:20AM |
Re: Bed Auto Leveling.. check this out November 04, 2013 12:34PM |
Re: Bed Auto Leveling.. check this out November 04, 2013 03:59PM |
Re: Bed Auto Leveling.. check this out November 07, 2013 12:45AM |
Re: Bed Auto Leveling.. check this out November 07, 2013 06:30AM |
Re: Bed Auto Leveling.. check this out November 08, 2013 01:22PM |
Re: Bed Auto Leveling.. check this out November 08, 2013 05:20PM |
Re: Bed Auto Leveling.. check this out November 08, 2013 09:46PM |
Yep, I'm testing it now on RAMBo, I've added this to the pins.h under the rambo section :Quote
JohnSL
This thread is very cool. I'm wondering, has anyone hooked a servo up to a Rambo board? Looking at the Wiki information, I'm guessing I would need to hook it up to pin 1, which is connected to the PWMExt pin holes in the PCB. Is this correct?
Also, for the 5V supply, is the pin labeled 5V always going to have regulated 5V that I can use for the servo motor?
Thanks,
-- John
#ifdef NUM_SERVOS #define SERVO0_PIN 22 #if NUM_SERVOS > 1 #define SERVO1_PIN 24 #endif #if NUM_SERVOS > 2 #define SERVO2_PIN 23 #endif #endifthis will make the servo use the MOTO-EXT pins, so MX1-3 is for servo 1, MX2-3 is for servo 2 and MX3-3 is for servo 3. The MX1-1 is 5V and MX1-2 is for ground, same for MX2 and MX3 (those are the 5x3 pins between the endstops and thermistors).
Re: Bed Auto Leveling.. check this out November 08, 2013 09:53PM |
Re: Bed Auto Leveling.. check this out November 08, 2013 10:37PM |
Re: Bed Auto Leveling.. check this out November 09, 2013 07:25AM |
Re: Bed Auto Leveling.. check this out November 09, 2013 12:48PM |
Re: Bed Auto Leveling.. check this out November 10, 2013 09:58AM |
Re: Bed Auto Leveling.. check this out November 10, 2013 11:18PM |
Re: Bed Auto Leveling.. check this out November 11, 2013 01:44PM |
Re: Bed Auto Leveling.. check this out November 11, 2013 07:25PM |
Re: Bed Auto Leveling.. check this out November 11, 2013 11:19PM |
Re: Bed Auto Leveling.. check this out November 12, 2013 11:50AM |
Re: Bed Auto Leveling.. check this out November 12, 2013 04:47PM |
