Re: Bed Auto Leveling.. check this out September 16, 2014 03:43PM |
Re: Bed Auto Leveling.. check this out September 16, 2014 04:14PM |
Re: Bed Auto Leveling.. check this out September 16, 2014 05:38PM |
#if defined (ENABLE_AUTO_BED_LEVELING) && (PROBE_SERVO_DEACTIVATION_DELAY > 0) // if (axis==Z_AXIS) retract_z_probe(); #endif
Re: Bed Auto Leveling.. check this out September 16, 2014 06:42PM |
Re: Bed Auto Leveling.. check this out September 17, 2014 12:08PM |
Re: Bed Auto Leveling.. check this out September 17, 2014 01:03PM |
Re: Bed Auto Leveling.. check this out September 18, 2014 06:28AM |
Re: Bed Auto Leveling.. check this out September 18, 2014 11:29AM |
Re: Bed Auto Leveling.. check this out September 18, 2014 02:21PM |
Re: Bed Auto Leveling.. check this out September 18, 2014 02:37PM |
Re: Bed Auto Leveling.. check this out September 18, 2014 04:38PM |
Re: Bed Auto Leveling.. check this out September 19, 2014 05:49AM |
Re: Bed Auto Leveling.. check this out September 19, 2014 11:04AM |
szabi
After each bed leveling process should I store the settings with M500? Is it only working if it is stored in the EEPROM?
Re: Bed Auto Leveling.. check this out September 19, 2014 11:57AM |
stephenrc
szabi
Not necessary. I have the eeprom disabled and the bed leveling works fine. I disabled it because I would never remember to update the settings and I have never changed them with the lcd.
Re: Bed Auto Leveling.. check this out September 19, 2014 01:50PM |
Re: Bed Auto Leveling.. check this out September 22, 2014 01:36PM |
Re: Bed Auto Leveling.. check this out September 22, 2014 01:52PM |
Re: Bed Auto Leveling.. check this out September 22, 2014 02:25PM |
stephenrc
Changing the hotend/extruder wouldn't change the x&y offsets much, just the z offset would be affected the most. I have two hotends, one used for abs and another for pla. They both have different z offsets but the nozzles have the same x&y offsets.
Re: Bed Auto Leveling.. check this out September 22, 2014 02:35PM |
Re: Bed Auto Leveling.. check this out October 07, 2014 01:10PM |
Re: Bed Auto Leveling.. check this out October 08, 2014 08:27AM |
Re: Bed Auto Leveling.. check this out October 08, 2014 02:57PM |
Re: Bed Auto Leveling.. check this out October 08, 2014 05:09PM |
Re: Bed Auto Leveling.. check this out October 09, 2014 04:47AM |
Re: Bed Auto Leveling.. check this out October 09, 2014 03:27PM |
derletztename
Thank you for your reponse.
No, no endstops get hit. The printer moves away from zero while the G92.
After the G92 it stays in the left back corner, where the last point of the G92 was and then really slowly move a little to the right and down towards the bed. From there it starts its printing as if there is 0/0 (the origin of the bed) now.
Re: Bed Auto Leveling.. check this out October 09, 2014 03:43PM |
AbuMaia
In Slic3r you can set the Z offset under the Printer Settings tab. You can save different profiles for whichever hotend you're using.
Re: Bed Auto Leveling.. check this out October 09, 2014 04:08PM |
Re: Bed Auto Leveling.. check this out October 10, 2014 03:56AM |
derletztename
A lot of hacking has been done there^^
Re: Bed Auto Leveling.. check this out October 11, 2014 10:10PM |
Re: Bed Auto Leveling.. check this out October 12, 2014 03:58AM |
