Re: Bed Auto Leveling.. check this out April 23, 2015 10:50AM |
Re: Bed Auto Leveling.. check this out April 23, 2015 05:53PM |
Re: Bed Auto Leveling.. check this out May 04, 2015 05:52AM |
Re: Bed Auto Leveling.. check this out May 06, 2015 03:55AM |
Re: Bed Auto Leveling.. check this out May 07, 2015 08:42AM |
Re: Bed Auto Leveling.. check this out May 07, 2015 06:06PM |
RiaanLR
Hope you can help.
I have the latest version of Marlin. Built my P3Steel a month ago. Using Repetier Host and Slic3r.
Re: Bed Auto Leveling.. check this out May 07, 2015 06:27PM |
Re: Bed Auto Leveling.. check this out May 07, 2015 06:54PM |
Re: Bed Auto Leveling.. check this out May 08, 2015 07:49PM |
Re: Bed Auto Leveling.. check this out May 10, 2015 04:05PM |
Re: Bed Auto Leveling.. check this out July 24, 2015 10:26AM |
Re: Bed Auto Leveling.. check this out July 30, 2015 10:07AM |
Re: Bed Auto Leveling.. check this out July 30, 2015 01:25PM |
Akegata
I'm trying to set up bed leveling as per Thomas Sanladerers video (https://youtu.be/EcGFLwj0pnA), using a LJ12A3-4-Z/BY sensor.
I've soldered the cables to the proper resistors, however, I can't get readings that make any sense from it.
I get readings fluctuating between 6v and 11v no matter if the sensor is opened or closed.
When I only connect power and ground without any resistors, I get 12v/0.5v, so it seems like the sensor is working.
Does anyone have any idea what could be wrong?
It's a bit hard to see everything in the picture, but that's what the connections looks like.
Re: Bed Auto Leveling.. check this out August 08, 2015 06:14PM |
Re: Bed Auto Leveling.. check this out August 11, 2015 05:52AM |
Re: Bed Auto Leveling.. check this out August 11, 2015 07:21AM |
Re: Bed Auto Leveling.. check this out August 11, 2015 07:26AM |
Re: Bed Auto Leveling.. check this out August 11, 2015 09:24AM |
Re: Bed Auto Leveling.. check this out August 11, 2015 01:21PM |
Re: Bed Auto Leveling.. check this out August 17, 2015 08:57AM |
Re: Bed Auto Leveling.. check this out August 17, 2015 10:02AM |
Re: Bed Auto Leveling.. check this out August 17, 2015 10:23AM |
Re: Bed Auto Leveling.. check this out August 17, 2015 10:43AM |
Re: Bed Auto Leveling.. check this out August 17, 2015 04:55PM |
Re: Bed Auto Leveling.. check this out August 18, 2015 10:09AM |
Re: Bed Auto Leveling.. check this out October 23, 2015 07:04PM |
Re: Bed Auto Leveling.. check this out October 26, 2015 07:30AM |
Re: Bed Auto Leveling.. check this out October 26, 2015 11:29AM |
Re: Bed Auto Leveling.. check this out December 10, 2015 02:04PM |
Re: Bed Auto Leveling.. check this out December 10, 2015 02:53PM |
