Prusa 8" i3 power supply?
Posted by Djmanmatt
October 21, 2013 01:53AM
I just bought my first 3d printer Prusa i3 from MakerFarm and I was wanting know I have a pro power supply that outputs 13.8v 30a and 450w will this work.Iit only has 1 output. I know they recommend a ATX power supply just kinda wanted to use it. Thanks
Re: Prusa 8" i3 power supply?
October 21, 2013 02:25AM
That sounds ok, other than the 13.8v instead of 12v? What do others think?
October 21, 2013 04:45AM
That's probably a better choice if it's a quality power supply. A good quality single rail PSU will outperform an inexpensive ATX PSU.
If it's a Printrboard in the latest revision it shouldn't be an issue.
October 21, 2013 10:43PM
Ok thanks. Now I was looking at the Ramps board and there is 2 inputs a 5amp and 11amp if I only have one output on my power supply were do I go do I bridge them?
October 21, 2013 10:56PM
Correct me if I'm wrong, but the Ramps board can, at most, only handle 12v. And 13.8v wouldn't work.
October 22, 2013 12:11AM
I did find this it seams it depends what kind of diode it has can very the voltage it can take. Wiki
October 22, 2013 09:41PM
The Ramps 1.4 board will handle a lot of voltage (like 35V). The Arduino Mega that's attached to the Ramps probably will get unhappy above 12 volts. It most certainly will die at anything approaching 20 volts.
The board will handle a lot of voltage.... The capacitors used on this or that build may or may not handle anythig over 16 volts. With derating that puts you into the "not a good idea" zone at about 14 volts.
Edited 1 time(s). Last edit at 10/23/2013 01:01PM by uncle_bob.
October 22, 2013 09:59PM
My post was specific to the Printrboard but as noted there is a diode configuration that will allow RAMPS to operate at a higher voltage while providing the ATMega with the proper voltage. All the RAMPS I've used recently have the diode config though one should still check.
To connect the PSU I double stack hook up wire and run to each set of terminals on the board. They can be jumped at the terminal block but I find stacking the lugs at the PSU to be a cleaner solution and easier to implement.
Edited 2 time(s). Last edit at 10/22/2013 10:10PM by vegasloki.
October 23, 2013 11:51AM
On the standard Ramps 1.4 board there is a diode between the bulk power supply and the supply to the Mega board. If you remove that diode, the Mega can only be powered via USB. If you want a stand alone solution, you would need some sort of secondary regulator to take your "high voltage" power down to a more Mega friendly level.
October 27, 2013 07:01AM
Meh,
Just be safe and get a 12v powersupply, they are only 30 bucks anyhow.
October 27, 2013 09:14AM
The MeanWell S-350-12 is a very nice 12V 29A supply. It's built in fan is quiet enough that you don't notice it over the noise of the printer.
October 27, 2013 04:13PM
Yeah, I agree with luigi and uncle_bob...
