Why are my Circles still ovals? Ive ruled out backlash.
Posted by prcdslnc13
October 28, 2013 10:10PM
Hey guys! I have a prusa mendel running marlin on a ramps 1.4. Im using gt2 belts with 20 tooth pulleys on xl belt on Y with an 11 tooth pulley. There is no measureable backlash on x or y when measured with a .001" indicator.
my circles are still coming out as ovals though and its driving me nuts. The x axis seems to be the issue though, the long axis of the ellipse traverses the y axis. I am beginning to think that this is due to my acceleration values. I am using the default values in Marlin, but I am using 1500 on profiles and 3000 on infill in slic3r.
Do you guys have any ideas?
Thanks
Re: Why are my Circles still ovals? Ive ruled out backlash.
October 28, 2013 10:52PM
here are some examples of what I mean.
open | download - oval1.jpg (101.9 KB)
open | download - oval2.jpg (153.5 KB)
October 29, 2013 07:11AM
First - what happens when you print something square? The issue could easily be X / Y calibration values.
If it's acceleration, printing slowly should eliminate the issue. That's pretty easy to do as a debug tool.
October 29, 2013 08:29AM
It doesn't matter which axis is longer, but which axis is incorrect. You have an expected diameter, which one is correct. Your error found be on the y axis.
Another thing to consider is whether or not you have your micro stepping jumpers properly installed.
October 29, 2013 09:51AM
It looks to be a calibration issue. This is the 25mm hollow calibration cube. As you can see the x axis is pretty much dead on, or as close as I trust digital calipers to measure, and y is off quite a bit. I swore I had this all straightened out. Ill mess with my step settings tonight and get back to you guys.
Thanks alot!
open | download - xaxis.jpg (46.7 KB)
open | download - yaxis.jpg (40 KB)
October 29, 2013 12:43PM
You can print a lower, but wider cube to do this sort of calibration. Printing a 5 or 10 mm tall cube goes a lot faster than one that's 20 or 30 mm tall.... One that is 50 x 50 or 100 x 100 helps take out the "rough edge" errors. It may also give you more confidance in your calipers.
October 30, 2013 10:38PM
Hey Guys. Looks like it was a calibration issue. I swear everytime I use the reprap calculator it gives me a different value haha. But its pretty dead on now. Within .2-.3mm which Im pretty happy with on a prusa. Thanks for the help everyone. I appreciate it!
