Hello All
I have a MendelMax 1.5 from 3Dprintertek.com.
Here is the issue. It will be printing away just fine and then randomly the Z axis will just jump up 2 to 5mm and print in the air.
For example it printed up to 5mm then is will move up to the next layer but it will move up 3mm and start printing in air.
It will do this with any file that I have tried.
I have sent one of my slic3 files to 3dprintertek and they printed it just fine.
So I sure that it is not the slic3 file (at least I think so).
Things that I have done.
1. Ground all the aluminum extrusions, Y axis aluminum bed parts and connected the power supply 5V negative to ground. All this help the display from get messed up but not the Z Axis jump issue.
2. Replaced the Arduino 2560 with a different one load with Marlin 1.0. This was the fix I though but then it did it again.
Any thoughs?
It was late last night when posted this and I forgot the photo.
And thanks for all replies!
GeckospotNixie
Edited 1 time(s). Last edit at 12/01/2013 07:31AM by GeckospotNixie.
