RepRapPro's Pronterface crashes with out_of_range
December 08, 2013 02:06PM
Hello,
I finished successfully building of my Mono Mendel from RepRapPro and run into a problem with pronterface.
After clicking on one of the buttons hotend on/off and heatbed on/off pronterface terminates with:
terminate called after throwing an instance of 'std::eye popping smileyut_of_range'
what(): basic_string::at
I looked into the python files and added some print commands to locate the problem.
It crashes after execution of setbedgui in pronterface.py. But why ?
Printing is possible - before crashing hotend or heatbed is activated.
Python 2.7.3, openSUSE 12.3 64bit
Help would be nice.
Re: RepRapPro's Pronterface crashes with out_of_range
December 08, 2013 03:42PM
Pronterface is nothing special. Vendors customize it a bit to add buttons that automatically send bits of gcode. Download the latest version from the source and see if it gives you the same problem.
December 09, 2013 01:31PM
Latest version works well.
Ini-files for slic3r are no longer in Printrun/profiles. Actual directory is .Slic3r
