Prusa mendel i3
Posted by MartinToniste
Prusa mendel i3
January 21, 2014 10:11AM
Hello, i am kinda new to this 3d printing. But i have followed it for years.
I want to build my own 3d printer. One that has got my intrest is the prusa i3.
My friend own somekind of high quality printer so i tough i could print the printable parts with his machine. I have google-d alot about which one to choose.
So here is my problem, i dont know what parts to get and how to build it. I found the prusa mendel i3 rework from thingiverse (http://www.thingiverse.com/thing:119616)
Does someone know some build guide or sth?
I want to start somewere. Also this is budget build.
Re: Prusa mendel i3
January 21, 2014 12:10PM
[github.com]
The scad files and siome documentations are there. Your first decision is probably to decide on the frame: box or single plate aluminum. There are also other versions out there that are available in kit form.
Re: Prusa mendel i3
January 21, 2014 03:44PM
I think box stile will be cheaper and steadyer. I saw that link bu i dont understand how do you read the codes, or am i just dumb.
Where can you get the electronics cheap?
Here is the hobbyking 3d printer electronics video. They will sell all the stuff very soon. [www.youtube.com]
They mentioned something about reprap also and seem same as the electronics that is needed. Am i right?
Edited 1 time(s). Last edit at 01/21/2014 03:55PM by MartinToniste.
Re: Prusa mendel i3
January 21, 2014 04:29PM
You have to use OpenSCAD to generate STL files from the scad files for printing in your friend's printer.
There are many sources for electronics for 3D printers that are better and probably cheaper than hobbyking. Look in the reprap.org for starters. This table is a good start. You can also look in ebay for good deals.
Re: Prusa mendel i3
January 21, 2014 04:49PM
I think i found the perfect set. [www.reprapsource.com]
And also a guy building it [www.youtube.com]
If i could get these parts i would be satisfied. Can someone combine some parts? I think i can work those codes out with my friend. But can someone link a correct parts list. Like the screws and mayby a link to the 3d printed parts i need. A website would be also nice were i could get the parts cheap. If the shop is in europe that would be awesome.
I am sorry if i sound a total newby, beacause i am a one atm. i just need a list. It is soo confusing right now.
If i get the same part i could but it together with the guide that the website gives witch is pretty good.
I think i could find the power supply and few of the rods in Estonia.
Edit, i think i found a electronics kit for reprap drom amazon[www.amazon.co.uk]
Will this work?
Edited 2 time(s). Last edit at 01/21/2014 05:13PM by MartinToniste.
Re: Prusa mendel i3
January 21, 2014 05:15PM
Download the whole distribution from github. If you're not sure how to use OpenSCAD to generate the STL, you can use the default box version that's located in the /boxframe/sample_stl folder. These were generated for use with parts and printer settings described in the readme.md in that folder. The readme includes a link with instructions for putting together the box frame.
The advantage of learning how to use OpenSCAD is that you can configure the printed parts and I would expect the frame to the vitamins (not printed parts) that are available to you and to the size of the print volume that you want.
Disclaimer: I haven't built a Prusa3 myself. This is what I understood from looking at the github files.
Edited 1 time(s). Last edit at 01/21/2014 05:17PM by brnrd.
Re: Prusa mendel i3
January 22, 2014 04:25PM
Ok so i started looking for electronics. Here is the list.
Electronics [www.aliexpress.com]
I will get the gt2 belt, pulley, 623zz, 608zz and lm8uu bearings from ebay. All the other stuff i shoud get loccaly.
I was making the list by this guy's list [www.danielhansen.net]
Can mayby someone add something that i am missing?
All the printable parts will print my friend. I should get the wood also and some bolt and nuts.
The list right now is 260€ it includes shipping and it dosent include the stuff i will get locally.
