Re: First unbox and Build - Prusa I3X DIY Tech Shop March 13, 2014 11:56PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop April 22, 2014 12:27PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop April 22, 2014 01:13PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop April 22, 2014 02:53PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop April 22, 2014 03:00PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop April 25, 2014 03:31AM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop April 25, 2014 04:05AM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop April 29, 2014 02:40PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 21, 2014 12:41AM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 25, 2014 01:34AM |
shah123
I am in the process of building one. I have a question. The hotend's black plastic piece which goes into x-carriage assembly just slides in there. It doesn't latch and it is wibbly wobbly and comes off easily. Is this the case with you all? The only thing that could potentially prevent it from dropping out is the filament going through it. Is that normal, or you guys hvae done something clever. I was thinking about taping it.
Also there is one plastic tubing in the hotend bag with the other components. Does this tube go into the plastic piece on one end and metallic piece on the other hand?
Thanks.
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 25, 2014 07:50PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 25, 2014 07:57PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 25, 2014 08:42PM |
Sorry it looks as if i confused you with the OP. Anyways, to attempt to answer another one of your questions, the the plastic tube is teflon (PTFE) and it goes in your hot end (after you put the metal piece in) from the "top." It's purpose is to keep the filament from sticking to the sides of the hot end as it goes through the plastic transformation temperature zone.Quote
shah123
Anybody?
shah123
Thanks.
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 27, 2014 12:29AM |
Shootquinn
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 27, 2014 12:33AM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 27, 2014 09:59AM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 27, 2014 06:31PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 27, 2014 11:18PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 28, 2014 01:29AM |
Shootquinn
Did you connect the provided jumpers with the jumper locations under the stepper drivers?
see: http://reprap.org/wiki/RAMPS_1.4#Stepper_Driver_Boards
you want the setup for 1/16 step.
Re: First unbox and Build - Prusa I3X DIY Tech Shop July 28, 2014 11:32PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop August 09, 2014 08:24AM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop August 15, 2014 03:26PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop August 17, 2014 03:22AM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop September 06, 2014 07:16PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop September 06, 2014 09:18PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop September 06, 2014 09:29PM |
Wow, really? Dang, kinda disappointing since they said it prints 9"x9"x7" (and even though that's rounding, the millimeter equivalent is closer to 8.6" square). Oh well, still going to buy it but glad I now know to go with the 8" square glass for the bed. Thanks a lot for saving me on that one!Quote
Thelandofthedave
My heated bed from diy tech shop is 8.25" square.
Re: First unbox and Build - Prusa I3X DIY Tech Shop September 10, 2014 04:08PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop September 10, 2014 05:25PM |
Re: First unbox and Build - Prusa I3X DIY Tech Shop September 10, 2014 06:09PM |
Ahh, dang, was afraid of that, I only have an old soldering gun laying around, and the precision on that thing isn't great so might not work, but I guess I'll see when the printer comes. And yeah I knew that about the crimps, but it was n9jcv who said he decided to just solder the two halves of the cables for the end stops, stepper motors, etc., instead of using the crimps, that's what I was referring toQuote
shah123
The heated bed needs soldering the cables. The cables carry a lot of current and hence they are thick. The crimps are for connecting the end stops, and the stepper motors to RAMPS etc.
Re: First unbox and Build - Prusa I3X DIY Tech Shop September 10, 2014 06:21PM |
