MatlsDoc
Vetteguy,
I've started having the same problem with the same setup, except I have the magma hot end with the 0.4mm nozzle. I think we have a blockage of some kind. I've noticed that there is ABS squeezing out between the extruder barrel and nozzle on my setup, which doesn't seem good. Anyone else experienced this?
Doc
MatlsDoc
Vetteguy,
Doc
I talked to Colin about your problem and he thinks you might have the fan hooked up incorrectly. He said most people make the mistake of hooking up the fan to the Ramps board. I guess the fan needs to be hooked to the power supply so it runs all the time and not just some of the time like the Ramps board makes it.
??? Hope this helps!
Edited 1 time(s). Last edit at 02/09/2014 07:14PM by vetteguy112233.
