LulzBot's TAZ Printer? February 07, 2014 12:04PM |
Re: LulzBot's TAZ Printer? February 07, 2014 12:07PM |
Re: LulzBot's TAZ Printer? February 07, 2014 08:56PM |
Re: LulzBot's TAZ Printer? February 08, 2014 10:13AM |
Re: LulzBot's TAZ Printer? February 08, 2014 11:42PM |
Re: LulzBot's TAZ Printer? February 08, 2014 11:44PM |
Re: LulzBot's TAZ Printer? February 09, 2014 12:12AM |
Re: LulzBot's TAZ Printer? February 09, 2014 01:54AM |
jebba
How is TAZ not a RepRap? Or would you exclude the Prusa Mendel, MendelMax, etc. as well? Just curious.
Re: LulzBot's TAZ Printer? February 10, 2014 12:55PM |
Re: LulzBot's TAZ Printer? February 11, 2014 11:47PM |
stonedcoldskier
- I chose to use stepper motors with integrated trapezoidal lead screws rather than the specified threaded rod. This added over $100 to the build cost, and required me to change the Z-nut holders, but they're dead-straight and the motion of the axis is silky smooth. I bought them from Robotdigg.com, here: [robotdigg.com]
...- I chose to use larger, high-torque steppers [robotdigg.com], which required slightly taller Y-ends and some supplemental feet in the middle of the frame.
Re: LulzBot's TAZ Printer? February 12, 2014 04:20PM |
Re: LulzBot's TAZ Printer? February 13, 2014 05:04AM |
stonedcoldskier
I self-sourced and built a Taz clone this fall and printed all of the parts on a Prusa Mendel V2 that I have owned for about 1.5 years. I am, very much, on the fence as to whether I would recommend that you build your own. I like the machine, but it has taken several refinements in order to realize my expectations. I realize now that I should have created a build log, but I will try to remember all of my changes...
- For starters, take a look at Thingiverse and refinements others have made here: [www.thingiverse.com]. The user 1013 has some great improvements and upgrades, espeically his stiffened X-Axis ends and extra-travel Z-ends.
- I added rigidity to the frame by using additional inside corner braces found here: [www.thingiverse.com]
- The original design made adjusting belt tension nearly impossible. I designed my own tensioning setup for the X and Y axes here: [www.thingiverse.com] and here [www.thingiverse.com].
- The original belt guides used 608 bearings on 8mm bolts. While the belt path was straight on the Y-Axis, the belt path was diagonal on the X and there was considerable error as the carriage got closer to the idler. I changed both axes to 128zz bearings [avidrc.com], (4 per axis) and 8mm shoulder bolts [www.boltdepot.com]. The smaller diameter bearings straightened out the belt paths and the shoulder bolts prevent over-tightening of the printed supports, which can result in a rather problematic failure.
I'm sure there are other things that I don't recall at this moment, but those were the highlights. With all things considered, I do like the machine but have changed just about every oringal printed part. If I were to do it over again, I would opt for a more rigid design. At the least, I would upgrade the extrusions to 30x30, and possibly even 20x40 or 20x80 for the base. I can say that Lulzbot has been great, and I can't thank them enough for sharing the design as open-source. The only thing that I bought from them was the $30 aluminum build plate, but they have answered questions along the way and even shared a few files with me that hadn't yet been published on the website. Overall, the build tallied just about $1300 using my beefed-up components.
Re: LulzBot's TAZ Printer? February 13, 2014 12:45PM |
Re: LulzBot's TAZ Printer? February 13, 2014 07:28PM |
Re: LulzBot's TAZ Printer? April 18, 2015 12:32AM |
Re: LulzBot's TAZ Printer? April 27, 2015 01:19PM |
Re: LulzBot's TAZ Printer? April 28, 2015 09:49PM |
Re: LulzBot's TAZ Printer? May 02, 2015 04:09PM |
