Prusa & Slic3r
Posted by BlaiddDrwg
Prusa & Slic3r
February 09, 2014 10:32AM
So yesterday I was exporting a gcode from a file I found on Thingiverse, it must have been pretty big because Slic3r quit on me during the export and now I can't get it to reopen. I've uninstalled and reinstalled Slic3r, and when I click, it'll popup in the dock (Mac) and then quickly disappear, like it's quitting again before it has the chance to fully open. Anyone have experience with this? I've been using the 0.9.9 OSx download that Colin recommends.
Thanks!!!
Re: Prusa & Slic3r
February 10, 2014 07:40AM
Im not sure about macs but on windows i know that can happen if the config file gets corrupted. And on windows it is not stored with the program files and is not removed when you uninstall. So my suggestion would be find the config file and remove it (maybe keep a backup encase it isnt the problem)
Re: Prusa & Slic3r
February 10, 2014 08:04AM
I've deleted Slic3r from my MacBook. When I re-download and open it, it seems to start opening and then it quits again. I've deleted it again. Part of me is tempted just to go buy a cheap PC.
Re: Prusa & Slic3r
February 10, 2014 08:06AM
What I am saying is you likely have not deleted the config file because it wont be stored with everything else
I looked about and it seems on a mac the files are stored here
/Users/Libraray/Application Support/Slic3r/print
/Users/Libraray/Application Support/Slic3r/printer
/Users/Libraray/Application Support/Slic3r/filament
have you removed these?
Edited 1 time(s). Last edit at 02/10/2014 08:07AM by lazzymonk.
Re: Prusa & Slic3r
February 10, 2014 08:08AM
Yeah, I've tried that but Slic3r doesn't even appear in my library or in application support. I'm thinking there's something preventing it from actually downloading to my computer.
Re: Prusa & Slic3r
February 11, 2014 07:41AM
This is what happens when I download and try to open Slic3r (Screen recording)
[www.dropbox.com]
Re: Prusa & Slic3r
February 11, 2014 10:52PM
What Mac OS are you running? It's probably not compatible with the latest Slic3r.
Re: Prusa & Slic3r
February 12, 2014 06:10AM
Mac OS (not Maverick), Mountain lion I think? Whatever was the most recent before Maverick--I can double check. It was working great until Saturday when it crashed.i was running the 0.9.9 per Makerfarm's suggestion. I did try downloading the newer version, but it did the same thing.
Edited 1 time(s). Last edit at 02/12/2014 06:12AM by BlaiddDrwg.
Re: Prusa & Slic3r
February 12, 2014 07:33AM
If it's Mac OS 10.5 and earlier, it won;t run the latest slic3r. You have to go back to slic3r 0.8.1 if you're running the precompiled package. Here's the release notes for 0.8.3.
Re: Prusa & Slic3r
February 12, 2014 07:34AM
Software OS X 10.8.5
Re: Prusa & Slic3r
February 12, 2014 08:16AM
Did you try running Disk Utility?
Re: Prusa & Slic3r
February 12, 2014 08:27AM
It says the Slic3r file is fine when I click verify on the Slic3r driver, the actual file (slic3r-osx-uni-0-9-9.dmg) doesn't give me the option to verify (or do anything else with it)
Re: Prusa & Slic3r
February 12, 2014 10:24AM
The IT guy at my work has my laptop now, hopefully he can fix the issue.
Thanks everyone!!!
Re: Prusa & Slic3r
May 14, 2014 02:37PM
Hello,
Im having the same problem. I am running Mac OSX 10.7.5
I open slicer and it disappears. What is the problem?
