I've printed out some replacement X-Axis Motor and Idler end pieces but the smooth rods slide into them quite easily not to the extent that they wobble but they pull out an push in with very little force ... while they are quite tight in the the parts I'm replacing and to insert or remove them while I can just pull or push using a twisting motion makes it much easier - if this makes sense ?
So the question is ... is this OK or should I at least redo the idler end ?
