Full Makerslide MendleMax Test run
Posted by Shanegt
February 27, 2014 09:49AM
Just got it mechanically done with all electronics running. All i have left is to tidy up and install an extruder.
This build is VERY sturdy, unlike my 2 i2s I have.
I did some speed test and it can FLY... Dunno if the extruder will be able to keep up with that speed.
What is the max speeds everyone is printing at successfully?
[www.youtube.com]
Re: Full Makerslide MendleMax Test run
February 27, 2014 07:39PM
I can immediately see one issue that you will have. The X-axis belt needs to be parallel to the movement of the axis where it attaches to the carriage. Otherwise the effective length of the belt changes as you move the axis from one side to the other, your belt tension will change, and you will have printing inaccuracies. To check this, move your X axis to the middle and test the belt tension. Then move it to one side. You will see the tension change.
Other than that it looks quite nice. My MendelMax is quite over-sized, which results in significantly reduced maximum print and travel speeds. My maximum comfortable travel speed is 130mm/s, and max reasonable print speed is about 70mm/s.
