Gen6 auto-level March 07, 2014 10:22PM |
Re: Gen6 auto-level March 08, 2014 01:03AM |
Admin Registered: 16 years ago Posts: 1,470 |
This makes no sense. Having three mounting points is ideal for leveling the bed. Position the extruder over or next to one mounting point and home the Z axis (carefully! if the bed is way off you don't want to crash into the bed!). Adjust the bed leveling screw so that the nozzle just touches the bed (some people like to use a thin sheet of paper to set the nozzle just above the bed). Move on to the second mounting point and repeat. Move to the third mounting point and repeat. You may have to repeat this process starting back at the first mounting point a couple more times before the bed is perfectly level.Quote
Guizmo12
only 3 springs to adjust so there is always one off side.
#define SERVO0_PIN 17
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Gen6 auto-level March 08, 2014 10:48AM |
Re: Gen6 auto-level March 08, 2014 11:03AM |
Re: Gen6 auto-level March 10, 2014 02:28PM |
Re: Gen6 auto-level March 10, 2014 06:26PM |
Guizmo12
It gives me "Sketch too big;" as an error...
Ah, I didn't notice that Gen 6 uses a 644p. In that case, you might not be able to use auto leveling on Gen 6 after all. Replacing the surface mount 644p would be pretty difficult, though possible. How big is the compiled firmware size? The 644p has 64k available flash memory, of which a few k is used for the bootloader.Quote
randyf1965
You need the Atmega 1284p not the 644p to enable autoleveling.... I have a 1284p in the mail hopeful I will have it today or tomorrow so I can autolevel
Re: Gen6 auto-level March 11, 2014 09:09AM |
