Z-Axis Nut coming loose March 31, 2014 08:20PM |
Re: Z-Axis Nut coming loose March 31, 2014 10:23PM |
Re: Z-Axis Nut coming loose April 01, 2014 04:06AM |
Re: Z-Axis Nut coming loose April 01, 2014 04:18AM |
Re: Z-Axis Nut coming loose April 01, 2014 05:20PM |
Re: Z-Axis Nut coming loose April 03, 2014 02:54AM |
mrstuky
It wasn't. Measurements were exact but for some reason the nut just came loose. I simply crazy glued the nut in place. The nut holder seems too large for this dam nut.
Re: Z-Axis Nut coming loose April 03, 2014 09:55AM |
Re: Z-Axis Nut coming loose April 06, 2014 04:39PM |
Yes you are right I whas probably tired and did not use my head as it whas under my arm that timeQuote
SheldonE
Um, won't that stop the nut from moving? The issue is the nut's coming out of the nut trap on the Z carriage. Cross tensioning and locktight are just going to fix the nut in place, which will be bad if you want the Z-axis to move.
Re: Z-Axis Nut coming loose April 15, 2014 04:42PM |
