Recommend an i3 x-carriage and extruder? May 04, 2014 09:57PM |
Re: Recommend an i3 x-carriage and extruder? June 01, 2014 10:20PM |
Re: Recommend an i3 x-carriage and extruder? June 02, 2014 09:24PM |
Re: Recommend an i3 x-carriage and extruder? June 03, 2014 02:36PM |
The extruder can be also used with only direct drive for example. Then it allows easy future expansion.|
Re: Recommend an i3 x-carriage and extruder? June 03, 2014 08:52PM |
Opus
In the end I went for the stock extruder/x-carriage on the github site for the i3. The extruder is fine (and fits the E3d well), but I think I might try a 4 bearing x-carriage at some stage. All the 8mm rod we get here is really 7.94mm and the bearings rattle around on them. I'm thinking adding another bearing might cut down on the amount of play.
Re: Recommend an i3 x-carriage and extruder? June 03, 2014 09:05PM |
CptanPanic
Opus
For the stock extruder, what extruder type did you set in scad file for e3d? groovemount?
